Apex Digital Master
- Posted on Jan 19, 2011
Re: The tv won't come on. its like theres no power...
Here are some DIY steps that may help you fixing the
problem.
- Check
the power cord - check the cord it might be opened (no continuity).
- Check
the internal fuse - sometimes the fuse fail by itself due to power surge, replacing with new
one cure the problem. However if the fuse blew again then this is an
indication that you have a shorted parts on the power supply. If no
reaction and still the unit didn't power up then you have an open parts on
the power supply.
The next steps should be done by an expert or qualified technician
because isolating the problem on the regulator section is technical.
But first check if the unit is under warranty then avail it
because the manufacturer will fix it for you for free or a little charge only.
