I'm not too sure how you are trying to access the router (wired or wireless) or what operating system you are using, but you will need to manually set your IP address (through Network Properties) on the computer to 192.168.2.10 (for example) with subnet mask of 255.255.255.0. If you also want internet access you will need to set the Gateway and DNS to 192.168.2.1.
Once that is set you will be able to try bring the page http://192.168.2.1 again and configure the router from there.
Once you configure the router (i assume you want to turn on DHCP again) you can set your computer back to DHCP assigned IP and DNS.
1You can run the setup CD or manually configure it using the user interface of the router. 2.Since that is a router all devices that will be wired to it should automatically get an IP address from it. 3.Since they will be connected to the router you just need to enable file sharing on each computer.
do you have apppoe connection or dhcp? release your ip address (ipconfig/release) set your modem to bridge mode then connect modem and router. try to connect.
First open the internet explorer browser. On the Address bar, type 192.168.2.1.
The site will ask you for username and password. The default username is admin and password is 1234.
The edimax page will appear, click the quick setup wizard.
just follow the instructions. The site will ask of your broadband type; click the PPPoE x DSL and fill up the required information.
Type your Username, Password, and Service Name and other info.
HI,
Actually in short "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of rear side of a router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
