Question about LaCie (300728U) 250 GB Hard Drive
SOURCE: LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Posted on Jun 10, 2007
SOURCE: Re: LaCie icon does not appear.
run diskmgmt.msc create a partition then format it. done. if no driveletter .. assign it.
Posted on Jun 01, 2008
SOURCE: Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Posted on Sep 13, 2009
SOURCE: Macintosh computer not recognizing the LaCie external hard drive
First thing to check is whether the Mac recognises the LaCie hardware.
Go to the Apple icon, and select 'About this Mac/Computer' then more info, which will launch System Profiler, check the FireWire section under Hardware to see if your drive is listed.
Assuming it is, and that the Disk Utility program doesn't see the drive, then you'll need a Disk analysis program like 'Drive Genius' or a recovery program like 'Disk Warrior'
Should your drive not be seen under the FireWire section, you have an interface failure on the LaCie, which isn't terminal, you'll just need to put the drive in another HD case and then read the data.
Reply to this and I'll try and give more help depending on the results you get in System Profiler.
Posted on Apr 06, 2010
SOURCE: lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Posted on Sep 13, 2010
Mar 05, 2014 | Computers & Internet
Jan 03, 2010 | LaCie (300951U) 500 GB Hard Drive
Oct 17, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Jul 18, 2009 | LaCie (300770) 250 GB Hard Drive
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
Dec 31, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Jan 17, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Jun 29, 2017 | LaCie (300728U) 250 GB Hard Drive
Aug 19, 2010 | LaCie (300728U) 250 GB Hard Drive
50 people viewed this question
