Hi, follow the instruction below......
Rear
See Figures 3, 4, 5 and 6
Fig. 3: Pull up on the front of the lower seat cushion and disengage the clips
Fig. 4: Remohow do i take the back off on a 1999 nissan maxima - a796228.jpgs behind the center armrest ...
Fig. 5: ... and the bolts on the lower corners ...
Fig. 6: ... Then pull up on the seat to disengage the three clips on the top of the seat
To install:
The
Nissan maxima seats have electric adjusters, which allow you to move the seat
forward and backward, up and down, and tilt forward and backward.The
seats are securely bolted to the car's floorboard.
To remove the seat follow this procedure:-
First move the seat to forward direction.Then remove the plastic covers from rear side of the seat.If its hard to remove,use a screw driver to pry the cover. The slide covers fitted with bolts.remove those bolts by socket wrench.once bolts are removed,move seat to rear side.
Now remove cover from front side like you did in rear side.Remove the bolts from front side like you removed in rear side.This seats are electrically charged seat.So many a times there is a minor current saved in its connector.So to discharge this current. remove the battery cables and then disconnect the seat electric connector.Now tilt it a bit and remove the seat from the car.
----------Refit the seat in reverse.
also if you want detailed instruction with complete step by step information and diagrams.Please click this link directly:---
http://www.nicoclub.com/FSM/Maxima/2010/SE.pdf
---------on page number 67 and 109 its given diagram for bucket seat removal.
This should help.Thanks.Helpmech.
You will have to take the material and the foam off of the seat to get to the bolts that hold the back of the bucket seat on. Then unbolt the two torx headed bolts.
SOURCE: 97 Nissan pickup standard cab
The bucket seats from the 1995 Nissan Pathfinder should be an exact fit. The bolt holes and bolts should be the exact same and have the exact same hole locations.
You showed removal of the back seat. I need to know how to take the back off of the front passenger bucket seat.
You showed removal of the back seat. I need to know how to remove the back off of the front passenger bucket seat.
The back is held on by clips that take a certain tool.
I appreciate the schematics on seat removal, but it doesn't show how to take the back panel off of the front passenger bucket seat. I need to take this off to get to the air bag (side unit).
