Question about Husqvarna Lily 540 and 550
The presser bar lifter on my Lily 540 broke and now the presser foot stays down permanently. The plastic portion of the lifter (the lever) that is located on the outside of the machine is intact. It is the metal bar that actually lifts the presser foot that is broken. I can't find anywhere that carries this part for the Lily model and the only sewing store in our town took my money 8 months ago and still hasn't produced a part. Is there anywhere to get this part? Thanks!
Posted by mnorrisca on
Debbi's Sewing Machine Repair
  • Husqvarna Master
  • 7,365 Answers
Check with
sewingpartsonline.com
or
sewingmachineparts.net
Posted on Jan 20, 2011
Pressure foot won't stay up
The presser foot lift lever on many newer janome sewing machines will wear out with use. It can easily be replaced by a sewing machine repair shop or Janome dealer. Or you can look online for a "presser foot lifter" or "presser foot lift lever" making sure to find the correct one for your machine.
Mar 03, 2014 | Janome Sewing Machines
Can't get my presser foot to fall down when I let go of the lifter on my Pfaff 6085 sewing machine
Sounds as if the spring for the presser bar is broken OR the presser bar is dirty and needs cleaned and oiled.
Feb 25, 2013 | PfaFF Sewing Machines
How do I change a pfaff 1222 presser bar lifter? I ordered a replacement part, but now I don't know how to remove it.
If you are lucky, your part will come with instructions. Each machine is a bit different but basically you have to get into the needle bar/presser foot bar area. If you are Lucky you can get to the lever assembly without having to take out a bunch of bars. But I've only ever seen that once on an industrial machine. So you take out the presser foot bar... to get to the lever. Use caution. You want to be sure you know where and how the parts fit in there. Take your time... take pics or make notes.
Good luck
Nov 17, 2012 | Sewing Machines
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
I am sewing a knit fabric on my Lily 540 and it is skipping stitches like crazy. I have tried adjusting the tension and the stitch length with no success. seem to always have a hard time with getting even...
It sounds like you may be using the wrong needle. For knit fabric you need a ball point needle in order for it to sew correctly. A regular sharp type needle can cause the stitches to skip. Also make sure you have the right size for the type of fabric. Lighter weight fabric needs smaller size needle and thicker types need bigger sized needles.
Also make sure you have the right presser foot and the right pressure on the presser foot to get nice even stitches. A roller foot helps when sewing knit fabrics.
May 18, 2011 | Husqvarna Lily 540 and 550
Husqvarna Sewing machine
The H foot is the Teflon coated foot and it is used when sewing foam, plastic, plastic coated fabrics, leather and imitation leather.
Yes, you can get a darning foot for the Lily. My foot catalogue shows part number 412 54 17-45 and it is called the Darning/Quilting foot. It has a clear oval shaped "foot" and a spring lever which is placed above the needle screw. When I owned a Rose (sister to Lily!) I actually purchased a Brother foot that was exactly (and I mean EXACTLY) the same as this foot for half the price of the Husqvarna one. So if you have a Brother dealer handy, try there.
Apr 12, 2010 | Husqvarna Lily 540 and 550
Presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
Nov 04, 2009 | Brother XL-5130 Mechanical Sewing Machine
Faulty presser foot lifter on a singer 2110/2112.
I have seen these machines with broken presser bar clamps (something inside the head). If it is just a bind then some oil on the presser bar may work, if the clamp is broken then it is probably not worth fixing.
Jan 10, 2009 | Sewing Machines
Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Dec 31, 2008 | PfaFF Tiptronic 2030
On my singer 9005 the pressure foot lifter does not stay in the up position - does not hold the pressure foot up.
These plastic presser bar lifters do wear out a lot ,very common,,,,,,,,You can lift it up and file as close to the machine side on top just a couple of stroke son the file will usually give it a surface to hang on and it will stay up ,much easier than changing the plastic lever
Aug 09, 2008 | Singer 7444 Mechanical Sewing Machine
Sewing Machines Logo
290 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
sewcrazyshan
Level 1 Expert
tsalagi152
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
