"F3" on a GE microwave means you have a shorting membrane keypad.
It is part number WB27X10816 and Sears Parts Direct online indicates that the keypad is still available, but I have my doubts. You will just have to place an order with them, and they will notify you in a few days if it's not really available. Annoying, but they're the only game in town on this part.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have me replace it for you, I would do that for $54.95, which includes insured return shipping.
I would have you either order it and have them drop-ship it to me, or order it yourself and include it with your control panel assembly when you send it to me for repair.
If you decide to send yours in for repair, here is the info you need:
DISASSEMBLY
For disassembly info, you can watch the video at my site, or see these text files: http://www.microwavecontrol.com/safety.htm
http://www.microwavecontrol.com/disassembly.htm
Be very careful when disconnecting the cables & wires. I would photograph or mark the wires during disassembly. Also, some connectors have a locking tab: WHAT TO SEND
I really need the entire control panel assembly - the plastic frame, keypad and control circuit boards - as shown in the attached example photo.
(So once you've detached this assembly from the chassis of the microwave, no further disassembly is required or desired)
Yours should have a "mini-manual" (technical sheet) hidden either behind the grille or control panel. I'd appreciate if you send that, too. I'll copy & return it. And please include my repair formand include yourmodel numberandFCC ID numberfrom the tag, or e-mail or print a clear photo of the tag.
(The repair form has my address, shipping recommendations, payment information, and basic terms of service.) TURNAROUND
If needed, I can rush it for you if you simply write "RUSH" in just the top margin of my repair form.
WARRANTY Unless otherwise specified, I give you a one-year repair guarantee.
Thanks,
- William E. Miller, AS-EET
[email protected]
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
SOURCE: GE microwave f3 code
You have a shorted touch pad.. here is a link for a replacement.. http://www.pcappliancerepair.com/model-display.php
If you open up everything and examine the touch pad, you may see something that is causing the short and fix it, oherwise, you'll have to remove and replace it.. Hope this helps..
SOURCE: GE Sensor Microwave model JES1456wf001 error code F3....how do we
F3 is a shorted key pad. To prove this, unplug the ribbon cable of the key pad from the control board and this symptom should go away when you plug the AC cord back into the wall. BE CAREFUL!!!
SOURCE: f3 error code ge microwave
No, unfortunately the membrane keypad is not available as a separate part on this model.
You would have to order the control panel frame, which comes with a new keypad already installed.
The part number is WB07X10883 and you can get it for $86.82 here.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Testimonial: "Great feedback. I will follow it to a tee. Thanks"
SOURCE: F3 error GE Spacemaker XL 1800: Model JVM1851CD.
F3 on a GE / Hotpoint
microwave means you have a shorted membrane keypad (aka membrane switch).
If and when an oven is coming on or doing anything by
itself, this is very dangerous and can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open when it's not in use, and of course one should never leave a microwave unattended while cooking.
involved.
You can find
helpful exploded view diagrams and order parts by entering your full
model number here.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
have us
do this repair for you, we do that for $39.95 plus part costs nationwide.
Either way, we can let
you know what your options and costs would be and send you other
helpful info.
At
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
[email protected]
http://www.microwavedisplay.com
SOURCE: ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Error code F3 on many models of
microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the
fault. Spares can be aquired through your GE dealer. Visit GE's web site for a list of dealers and spare parts suppliers.
Hope this helps.
