this unit is compatible with a few of LaCie power supplies, but it is generally sold with the one providing hte following:
DC Output: 12V (2A) 24W Regards,
I have the same one. The power supply I have says input 100-240V output is 24W 12V 2A.
I'm replacing the power supply but my big problem is not knowing the polarity of the tip There is no sticker on the hard drive itself or on the power supply (that I suspect is fried). Can anyone help?
Lisa
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
I lave lots and lots of experience with LaCie Drives (I have 6 of the 2TB models). Every, every, every time a drive fails or runs slowly, it is the power supply. I have now replaced 5. They run very hot (so does the drive), and fail pretty often. It looks like the voltage drops just a smidge, and access times seem to increase, i.e., the drive "runs slow". Then it won't boot at all, and the blue light keeps blinking. Fortunately LaCie has replacement power supplies in the store. Buy a couple extra. I am married to the LaCie drives now, or I would probably switch brands. I kind of guess that they know about this because I contacted the help desk, and he wasn't surprised. Maxtor has a nice drive, and the Calvary drive is $150 cheaper. A drive is a drive I guess. By the way, if anyone is listening, how about building a QUIET, COOL drive with and INTERNAL POWER SUPPLY? GOT IT? All the cords and power supply bricks make me crazy. It might be nice to see a stackable drive where the top of one drive mates to the bottom of another, carrying network info as well as power to the drive above. Hint, hint. We all are building systems with ungodly amounts of storage. Too bad the manufacturers aren't building drives with the durability we need.
