Heating & Cooling Logo
Posted on Jan 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ruud M# ugra-06emaes won't start, has power, thermostat will not turn on fan on manual
  • tony5442 Jan 19, 2011
    ruud M# ugra-06emaes 90% + forced air furnace does not start, fan runs in manual position if heat on thermostat is in off position. When thermostat is switched to on position, fan runs for about 3 seconds and turns off.
Anonymous
Level 3:
  • Master 43,501 Answers
  • Posted on Jan 19, 2011
Anonymous
Master
Level 3:
Answers
43501
Questions
0
Helped
10835290
Points
101584
I think the problem is internal inside the furnace...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Oloyede Monsuru
Level 3:
  • Master 1,468 Answers
Oloyede Monsuru
Master
Level 3:
Answers
1468
Questions
0
Helped
407436
Points
4011
A common question on on our site is about different fan sound that happen and the causes. These noises are often fairly easy to fix and some are the result of other problems.
If you are hearing a rattling sound or a squeaking, high pitched squeal coming from the bottom or back or the refrigerator then the condenser fan motor is probably going bad. Sometimes the bearing in the fan motor will even get so bad that the fan blade will start to hit anything that is close to it down there. This can create a very loud noise. This fan normally will be running when ever the compressor is running also.
As with any other problems you will want to get these things fixed promptly. If the problem is just a squeal a bit of light motor oil will do wonderful things for you. Many times though, you will have to order the parts needed to fix the problem. When repairing the problem make sure to remove all power the the unit and to wear gloves is possible, as there are many sharp edges in close quarters that will butcher you hands in no time.
The other fan that can cause sound is the evaporator fan. While this fan too can get worn and become noisy, it also can sometimes start to hit ice that is building up because of a problem with the defrost system of the refrigerator. Checkout my tips about defrost problems if you find a build up of ice and the fan is hitting the ice and making noise. This fan can also be oiled if needed, and it will also wear out and need to be replace occasionally. This fan usually will go off when the door is opened, so sometimes it makes it difficult to figure out exactly what is happening. By holding the door switch in manually, you can get the fan to run and troubleshoot it more easily. Make sure to remove all power before trying to service the fan. Spinning fan blades do not play nice with your hands!
For many refrigerators you will have to remove some covers or even the whole bottom of the freezer to get to this fan for replacement. Checking the exploded views at appliance parts websites can give you an idea of where the fan is located and what must be removed to get to it for replacement.
Both of these fans and the associated parts are available for most refrigerators online. Look for them at the appropriate spots in the exploded views of the units.
Good luck and thanks for using fixya.
My Ruud Achiever 90 Plus MDL: UGRA-09EZAJS is 17 years old. Runs fine but wonder if I should replace the blower motor and go to a variable speed motor
The variable speed DC motors you describe do use less power but cost 14 times more too, not worth it especially with you motor running!
Ruud furnace, model UGRA I need to trouble shoot the fan control board.
Does it have the flashing light you can view thru the peephole and count the flashes? They will give you an idea.
Is the fan coming on? Describe the problem. don-ohio
I have RUUD furnace with build in coil for air conditioner and Weather King compressor outside of my condo. ALL EQUIPMENT IS 4 YEARS OLD I didn't have any problem with heat at winter, but in summe
When you remove the panel to the unit it turns off the power to it. The reinstalling the panel will reconnect power and allow the unit to reset. So the cheapest and easiest thing you can try is to replace the thermostat. Make sure you see how many wires you have connected to your existing tstat and buy near the same thing. It's possible that the tstat is acting up, not allowing the unit to cool when the temp demands. And turning off power is resetting the tstat as well as the unit. It will be hard to troubleshoot with the info provided so a new tstat will be worth a shot. Hope this helps!
2helpful
2answers
Ruud 90+ Model UGRA 10EZAJS Trips Out
Check for condensation buildup in the Induction Blower housing. The condensate tubes or canister may be blocked and causing the diaphragm switch to trip the unit out causing the burners to shut down.
Not heating inside the home
Turn your fan switch at the thermostat to on, if the blower starts that is
better news for you. If it does not start you will need to check the fuses
or breakers.
If you are electricity driven. Turn power off, remove blower door compartment, remove and label thermostat wires. Hook a jumper wire
between R and W. Put door back on, restore power, if furnace starts and heats your problem is probably the thermostat
2helpful
I have a Ruud 90 Plus Model UGRA furnace and blower starts immedi
NO BECAUSE THE BOARD IS TELLING THE FANS TO STARTARE THE CONTACTS FUSED TOGETHER OR STUCK IN THE CLOSED POSISTION CHECK THIS FIRST
Fan Won't Start
Check your circuit breakers.
Top Ruud Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
