LG DLE3777 Electric Dryer Logo
Posted on Jan 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an LG DLE3777W electic dryer that was making a sqeeking noise but is now making a banging and vibrating noise. I think the bearings are gone. I do not have a prts manual so I do not know what to replace. CXan you tell me what parts I should be looking for to order?
Tim Whalen
Level 3:
  • Master 3,076 Answers
  • Posted on Jan 18, 2011
Tim Whalen
Master
Level 3:
Answers
3076
Questions
0
Helped
824399
Points
9577
Drum rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
I don't know how quickly you need the parts, but on eBay they are cheaper:
http://shop.ebay.com/i.html?_nkw=dryer+drum+rollers+&_sacat=0&_odkw=dryer+drum+rollers+and+glides&_osacat=0&_trksid=p3286.c0.m270.l1313
Hope this Helped Tim
2answers
My lg washer is making a loud noise at the end of the wash cycle.
When you do hear your LG washing machine making a loud banging type of noise on the spin cycle it could be caused by overloading or a loud that is unbalanced Or the bearing has worn out and needs replacement.
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 • Dryers
1helpful
2answers
Tromm dryer
I don't know if your warranty is up but its covered if not. I have gone and swapped out dryers for same problem and they were LG's and It always seemed.to be those rubber wheels
May 29, 2013 • Dryers
SQIRREL CAGE ON BOTTOM RIGHT OF DRYER NOISY AND LOOSE...DRYER MAKES BANGING NOISE
sounds like the bearing may have gone out, here is a website they may help, even though it is for a Maytag it is the same thing , Tim:
http://www.ehow.com/how_4829560_fix-squeaking-maytag-dryer.html
2answers
I have a LG dlg5988w drying that just started making a banging sound. Are there rollers that need replaced?
yes the belt has a tensioner with a bearing and a roller surrounding the bearing
the bearing can be locked up which will put flat spots in the roller m,aking the banging noise
Sound horrifying at times doesn't it?
2answers
Dryer making noise when turned on
you have to specify what make your dryer is to be able to answer question
Feb 06, 2010 • Dryers
Hi, My LG dryer is making a sqeeking noise when turned on. Pretty loud at first and then sound reduces further in the drying cycle. Any suggestions?
If you can open one of the smalle panels to see inside around the drum- check to see if the belt is rubbing and there is black rubber dust or strings around that area. It is probably one of the bearings or felt gaskets or seals that the drum rides on.
Makes a noise sometimes when it is drying - like a sqeeking noise. Could this be the belt?
The reason to this problem is the belt.It might have gone
bad.You may need to replace it.
4helpful
Dryer has a banging noise
It Is fixable.All you need to is try to balance the load or a perfect concrete flat surface for the machine.
If the problem still persists, then during the previous vibrations, the shocks or the drum bearings might have been damaged, you might have well replace them to avoid further problems.good luck.and please post your comments.
5helpful
2answers
LG DLE3777W dryer thumps when running . It sounds like there are tennis shoes in the drum.
Probable cause is the bearing on the wheel that turns the drum is worn out. They are easy to replace and should cost less than $25. for the part.
Remove the front of the dryer and turn the drum by hand, you should be able to tell which side is worn.
Be sure and unplug first.
Top LG Dryers Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Dryer Expert? Answer questions, earn points and help others
