You need to open the remote as it’s probably full of greasy dirt for using it. Open and use a alcohol wipe to clean all of the buttons. Then it should work
on some old english cars the central horn button had to be pushed down and at the same time twisted to the left ( anticlockwise
the method of fixing was by a series of interlocking pegs that had to have the button depressed and turned so that the pegs no longer were captive and allowed the spring under the button to push the button out of the steering wheel hub
IF you do not disconnect the horn wires first you may drive the neighbours mad as pressing the button will sound the horn
push in and hold the sunroof button (30 sec) and the sunroof will go through the entire recalibration. That should fix it.
__________________ Hi apperently this is a common problem for BMW but this fix should do it. You will have to do it again if it happens. Good luck.
Push and hold down the start button again. The machine will stop. Turn to Spin (to drain the water that burped into the machine when you turned it on by accident). Hit start, let the drain and spin cycle complete. Hit the key button and you're all set.
Reset your Printer by following these steps for your Printer Model:
EPSON Stylus Color 900, 980
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
Try this,push the switch down and roll down the window continue to hold the button for three secon ds then roll the window up and continue to hold the switch up for three seconds.Do this again and see if it fixes your problem.
someone could have pushed the 4x4 low button accidently, it will not engage but the 4x4 will flash up on your dash. just push the 4x4 auto button and it should stop
