Hi jmtrego Listen you need to go into menu and then go into the connections. Then you need to check active syn on the zire . Next you check the pc connections to the zire
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
hi again jmtrego the active sync is in your menu under settings. If you don't see the active sync then it may b called hot sync. Also the cable cradle connections may not be the connection you want to uses. it should actually say pc and usb connection. do you have a usb cable to plug into your phone. ok let me know if this still doesn't work.
hELLO jmtrego go you have a bluetooth setting on the zire. The palms are all have their on way of trasnferring if you can't use the pc then use the bluetooth setting on the zire hard reset don'r really help the palms. You can call palm tech support. if you can't get it . But first you can blue tooth your sire to your pc you need to make the zire discoverable. under connections . their is a menu for connections.if you go to the prefd on the menu you will be able to do the connections.. did you buy the zire brand new. i think your zire isnt working properly. The code to unlock the zire is 0000. you hit the main menu and then settings then you should see an icon that looks like a lock.
Which menu? I found connections and selected cable/cradle but I don't see a selection "active syn". Could you be more spcific?
No luck. I don't see a usp option to select. My #1 unit is set for con3 even tho it is connected to a USP port. It works fine. I was able to beam my address file from #1 to my other unit but the other files are locked and I don't know how to unlock them. Frustration is setting in!
No luck so far, maybe the new unit is defective. Next I'll try IR.
