Question about Comfort Zone Heating & Cooling
I have a comfort zone heater 1500W Portable Quartz infrared heater CZ-1500WT For the first two years it worked perfectly - two weeks ago the electric plug end that goes into the receptacle gets extremely hot- it is on the same receptacle that we have used and had no problems - Why should this make our receptacles extremely hot? I tried another outlet also and it also got extremely warm We purchased this heater 8/19/2008
  • Diane Dekelver Nov 18, 2012
    Just was reading your article on the Comfort Zone CZ1500WT. It so happens that our heater has burned off two plugs and 2 recepticles. My husband tried to use it in our 5th wheel, but got scared after this happened twice. He put it back in the box & forgot about it. I just came across it again and thought I would see if anyone else was having this problem. I would like to contact Earthwise Technologies who apparently sells these units. Does anyone out there have a email address that I can contact and see if there is anything that can be done to resolve this issue. This happened since new, but thought it was the wiring in our 5th wheel. Seems not after reading this article. If anyone has any information to help, please email me at [email protected]
  • victorwil444
    victorwil444 Dec 20, 2012
    I bought a used Comfort Zone CZ1500P and am having similiar problems. The end of the cord is "warm." I'm not really sure what to do with it either. If I find out any other information on how to fix this, I will pass it along to you.
Rich Landrum
    Brigadier General:
  • 4,736 Answers
Unless you want a new house, stop using that heater immediately. There are severe internal electric problems with your heater. Since it's already 3 years old, I'm not sure it's worth trying to repair. With what you described, I'm surprised it didn't trip one of you circuit breakers.
Be safe, Don't continue to try to use this heater.
Posted on Jan 20, 2011
  • matt martin
    matt martin May 19, 2011
    You will need to rework the power supply board. You will have two bad capacitors. These two capacitors are of 16 volts at 1000Mf at 105 degrees. The other 4 capacitors are 25 volts at 220Mfs and at 105 degrees. Replace all six of them.This will cure your problem. Thanks for listening and show all hands of support!
Enerzen customer Service address ... website phone number anything. I can find a remote?
New Enerzen 2000 Sq Ft Infrared Quartz Electric ... - eBay
www.ebay.com > ... > Heating, Cooling & Air > Space Heaters
eBayNew Enerzen 2000 Sq Ft Infrared Quartz Electric Portable Watts Heater in Home & Garden, Home Improvement, Heating, Cooling ... Duraflame Colby 1000 Sq Ft 1500WInfrared Quartz Electric Portable Heater Cherry ..... (1) Owner's Manual ...
Enerzen pro heater manual - Fixya
Nov 29, 2015 | Heating & Cooling
Comfort Zone Infrared Quartz Heater is not staying on it cut right off. Please advise
Clean the filter and the element. Make sure that they are dry before you re-install them. Check the power cord and socket for damage..
Feb 21, 2015 | Comfort Zone Heating & Cooling
Comfort Zone CZ 1500 A04 CONTINUES TO COME ON
The AO4 is a board used by Earthwise on the Comfort Zone Heater. The reading is the board being used. If the heater just gives that reading it may need to be reset. This can be done by pressing up, down and enter at the same time. If this does not work unplug and try it again. Hope this helps
May 04, 2011 | Comfort Zone CZ1500WC Infra-Red...
My comfort zone infrared hearter has a display message of A05 and will not run, what does that mean? How can I fix it?
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
Nov 16, 2010 | Comfort Zone Heating & Cooling
Need manual for serial # E0825340 model CZ 1500 wt
my comfort zone cz1500wt shuts off when turned on code A03 appears on the display
Oct 25, 2010 | Comfort Zone NEW 09 Electric Portable...
Settings on my CZ 1500
To switch between C and F, hold DOWN and ENTER for three seconds.
( I sell these. )
Mar 11, 2009 | Comfort Zone NEW 09 Electric Portable...
Heating & Cooling Logo
1,655 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Marvin
Marvin
Paul Carew
Muntejaya Ginting
Muntejaya Ginting
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
