SOURCE: water leaking from wash machine
It is probably a seal that is on or near the bottom of the tub. Dirt and grim wears at this seal over time. The leak is slow so it is hard to visually see.
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
SOURCE: Grease, or some substance on clean clothes
You need to thouroughly clean the large door seal in all of its grooves and the inside of the door as well. Just put on gloves and use detergent to do this and rags or pape rtowels. Also make sure the inside of the tub is clean and that you are not overfilling the washer. Good luck.
SOURCE: Frigidaire GLTF2940ES Front Load Washer
use Affresh. It is a tablet that you put into your washer and run it alone. You can buy it where you buy your front load washers. I bought it at Best Buy. hope this helps
SOURCE: Washer won't drain or spin
your not going to like me? its the programer playing up,,,pricy part too?
see i was right,,,you hate me now!
