You MAY be overdriving the sound card. Near flat should work for vocal, but setting the levels throughout the mixer is important as well as the sound card. You can use the LOW CUT to reduce hum if you have noisy system. Describing balancing the levels is more than I can do here. There are many good videos about mixer setup on YouTube.com. You cannot "fix" problems created by improper levels and noise injected into the system using the EQ.
What is important is to see that all gain controls and faders are around mid range to 70% when operating normally. You should be using BALANCED lines everywhere possible either XLR or TRS cables. ALL interconnected equipment should be powered from the same receptacle or power source INCLUDING all amps and powered speakers. Often users use unbalanced lines from mixers to sound boards and pick up noise or they have the levels set wrong between the mixer and sound board resulting in clipping and distortion or poor signal-to-noise ratio.
