Minolta DiALTA DI2510F All-In-One Laser Printer Logo
Anonymous Posted on Jan 18, 2011
C500 error message on a di2510f - Minolta DiALTA DI2510F All-In-One Laser Printer
Norman Weimar
Level 3:
  • Minolta Master 7,035 Answers
  • Posted on Feb 22, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7035
Questions
Helped
1910594
Points
11959
Kerry,
First check the right side cover where the image unit is located. Check the two latches that latch the door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
C0500 mean the fuser the hot part is not getting the 117VAC power to the lamp inside the upper fusing roller. people sometime get frustrated and slam the right side breaking one or both of those latches prevent the door to push a accurator into the machine to depress a switch to supply power to the fuser lamp
C0500
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
What is error code co650 and how can i solve it???
85891187-9b04-4baa-96e0-b14b7222e224.jpg 365e71fb-1b1a-46cb-a9f1-b5f6b31b7d3f.jpg 365e71fb-1b1a-46cb-a9f1-b5f6b31b7d3f.jpg1. Press the COUNTER. 2. Press the following keys in this order:
STOP 0 0 STOP 0 1
3. Enter the code number corresponding to the function to be used from the KEYPAD.
4. Press the START.
<Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
C500
first ensure the right side is closed (Section that exposes the drum cartridge) and that the latches are not broken OK with machine on take a paper clip end stick in the tiny hole on the right side of the control panel (From then on you can only use that paper clip:):):) for this procedure (Copier Tech humor:)) The paper clip is going to touch a small switch which turns the to several screens if its say abort that is ok what you are looking for is going to be on left side of the screen in the middle a small purple dot when you see the dot press 3 that will activate trouble reset it will still code out with your c500 code but now go to utility mode see the new button Maintenance touch it you will see trouble reset touch that machine will go thru the entire cycle again you will see the small dot DO NOT touch let it go to "Ready to Copy" if not you have a problem with fusing unit the Hot part DO NOT CONTINUE TO RSET you can catch the machine on fire have a tech come out a look at it.
Error code c0960 on my Di2510f
Manual by pass tray lift the by pass tray is the step looking thing on the right side of the copier. check to make sure there is nothing stuck inside there. IF ok then mite want a tech come out and look at it
9helpful
6helpful
MY Di2510f is jamming and throwing the code C004E can anyone tell me If I replace the fan will it continue to jam or will it stop the jamming?
Replacing the fan will only help you with that error code c004e. The jamming will be an entirely separate issue. Where is the machine jamming? Fuser area? Cassettes? Document Feeder? Please clarify.
8helpful
2answers
I am getting error code C0045 on the Minolta Di2510f
Error C0045 indicates a cooling fan motor malfunction. Either the cooling fan motor or the master board needs replaced. I have a copy of the service manual on PDF if you would like to attempt the repair yourself.
2helpful
Error message
C0910, C0911 2nd drawer lift problem
Robert
Workpad c 500 chunk overlocked problem
when trying to print a screen after saving information, i get the message line 3061 chunk overlocked. lt requires a hard reset to get the ibm workpad c500 to work again, and the information that was entered prior to the message is lost.
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
