It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it. YOUR
SAFETY IS PARAMOUNT This is a job for a professional but if
you are safety clued up, here's instruction. Load
test. A
simple safety test.
Make sure the
!!!!capacitor is discharged!!!!! before attempting any
sort of repair.
Check the door interlock switches first then the
high voltage diode with either an AVO model 8 or moving coil meter on
high resistance range for short circuit, (DVM's won't show the
fault!), the capacitor can fail and go short circuit, the feed fuse
on the primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
Hope that helps.
Place 1/2 litre of water in a glass container.
Measure the temperature of the water.
Place in microwave and heat
on full power for 1minute.
Measure the temperature after it has
stood for 1minute.
If the temperature difference is more than 9
degrees Celcuis the magnetron is working and producing about 700Watts
of heat.
If your microwave is labelled with 900 or 1000Watts. That
is about right.
If the temperature is less then the magnetron is
not working properly and may need replacing.
This
a only a rough guide and any doubts you should consult an authorised
service agent.
Since the light and fan work the main board or the processor is working .Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
As there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
