Computers & Internet Logo
Posted on Jan 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am using the libyamax internet and i did install the device but still not conected
Daedelus Computing
Level 2:
Scholar:
  • Expert 111 Answers
  • Posted on Jan 18, 2011
Daedelus Computing
Expert
Level 2:
Scholar:
Answers
111
Questions
Helped
11376
Points
337
When you set up your route, did you make sure that DHCP was enabled? And on the computer, right click on your network adapter and go to properties, make sure that it is set to obtain an IP address automatically.
1helpful
Why Thinkpad T23 2647 4MP can't conect net after installed windows XP?
I do not use an automatic driver detection program, because they have a tendency to install the wrong drivers.
I look in Device Manager, and use the driver that matches THAT device, the O/S used, and is the newest version, (Date), with all the bugs worked out from an older version.
For your laptop that would be;
Ethernet Driver for Intel PRO/100 VE LAN that is the 49675 version, and has the date of November 8, 2002,
http://support.lenovo.com/en_US/downloads/detail.page?DocID=DS002672
Regards,
joecoolvette
Once I conect my GPS to a usb cable, I get the black screen that says conect to computer, that being connected to the car. I thought that the gps needed to be coneected to the internet to get updates, I...
The screen your describe on your Garmin Nuvi is quite normal. It's the PC communication mode of the Nuvi. When disconnected from the PC it will automatically restart.
To update Nuvi software and maps - connect the Garmin to a PC / Mac using an USB cable. Then start your web browser (Internet Explorer / Firefox or similar) and go to MyGarmin.com.
To update the Garmin - MyGarmin.com will check if your webbrowser has been installed with the Garmin update plugin. If not it will say so and will lead you through the procedure to install the Garmin web browser plug-in.
After the web browser plugin is installed it will ask you for your Username and Password at MyGarmin.com. If not registered, then register yourself with the serial number of the Garmin Nuvi.
From here it's possible to update your Garmin Nuvi with new Nuvi software and maps using your username / password at MyGarmin.com
2helpful
What are the internet settings for tata docomo for HTC p3452 ... i have sent the message but it did not work....what is another way? please reply...
I use same htc p3452. I face same problem in airtel. Download Microsoft Acttivesync and instal in pc after conect device it will run ,and after you oprate Device -start- program -internet sharing -usb mode -CONECT,
Installing new wireless g business ethernet bridge my problem is i cant connect to ip address for set up 198.168.1.1 does not connect neither does192.168.1.226 what now. i have internet conection on 2...
You need to manully assign your computer an address in the 12.168.1.x range with a subnet mask of 255.255.255.0 rather than whatever is currently being used(most likely assigned by DHCP),
Once you do this and connect to the device, it is best to normally give it an address in your norml ip range, reset your computer back to normal, and then re-connect using the newly assigned address to verify it has been done correctly.
Depending on the model, you may also have the option of making the initial connection with a serial cable and then make any desired changes including device IP address by this method.
1helpful
No conection to internet by local network
hi! there,
if you have *********** board installer,install and the wizard will find your ethernet driver if this buit in ethernet,but if you have an external pci enthernet device go to device manager,left click and click the properties of fast ethernet pci device,try to update your driver on website.device maneger can find on control panel under
system,click hardware,click network adapter,click properties and click on drivers and update your driver.have a nice day.
Cannot connect to the internet in wireless
hey there
check whether the wireless is switched on and if the driver is installed properly by right clicking my computer- properties- hardware tab- device manager-
if the wireless device has an exclamation mark on it open it re-install driver providing you have the utilities cd for the laptop
Webcamera conection
1st You download Webcam Driver.
Webcamera conection
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Feb 22, 2009 • A4tech PK5
No internet conection having loaded AVG
Go to any internet browsing center and download the updates from the following link, take the copy into any flash drive and do the update on your PC where you have installed AVG
http://free.avg.com/download-update
2answers
Internet access
You do need to be within range of a wireless signal.
Have you installed the drivers for the card properly?
Does the wireless card show up under "network adapters" in Device Manager? If not you may have to reinstall the drivers for the card. Also make sure that it is FULLY inserted into the PCMCIA slot for it to be recognized by windows and be in working order.
3answers
Modem conection
In order to troubleshoot this problem, I need the following information:
Are you using a router?
What OS do you have?
Does your modem have a steady "online" light?
What IP address is coming up in ipconfig?
Grand Canyon Tech
Grand Canyon Tech
