Question about Reddy Heater-30-55,000 BTU Variable
It is full of kerosene however when I plug it in to start, it will not turn on. It makes the effort for about two or three seconds then turns off
Anonymous
    New Friend:
    Problem Solver:
  • 8 Answers
The safety is turning it off because it is not lighting. You did not mention if it was actually trying to light, or if it was just the motor running. If it is not lighting, take the top cover off and watch the ignitor. Depending on the type of ignitor, it will either glow or spark when you plug the heater in. This should happen before the fan starts running. Once the fan starts, you should be able to see a mist of fuel coming out of the nozzle. If there is no fuel spray you may have an air pump problem, which is on the back of the motor, or the fuel screen in the tank may be plugged.
1. Check for ignition source
2. Blower motor should start, if you have ignition
3. Fuel should spray out of nozzle, if not check filter and check for air flow out of the pump.
4. If you do not have any air flow, or not enough air flow check the pump. Pressure out is critical.
5. If pressure is too low check for leaks around the pump. Spray soapy water on the back side of the motor/pump housing. The plastic pump cover is bad about cracking, and the cracks are very hard to see. The plastic cover could also be loose on the pump.
6. While on this end of the pump; the filters need to be clean, as they will affect the pump pressure and upset the whole apple cart.
Posted on Jan 18, 2011
Kerosene Heater starts up and then shuts down
David, you need a copy of the Troubleshooting Manual here:
http://www.toyotomiusa.com/OwnersManuals/Portable%20Heaters/Name%20begins%20with%20LR%20or%20LS/LR-350%20LR-450%20Troubleshooting%20manual.pdf
It sure sounds like a failure during pre-ignition. Page 5 covers both of your burn times with two different Flow charts.
A yellowish flame can mean a warped flame ring or incorrect air flow.
Dec 29, 2014 | Heating & Cooling
All Pro Kerosene SPC-K50 runs intermittenly
This type of heater can be temperamental because they are often stored for long periods in unsuitable conditions, aren't serviced very often and the remnants of fuel are left inside the tank during storage.
Kerosene has a fairly high natural water content, the tank is vented and normal air pressure changes will allow further moisture and dirt to enter the heater.
Good heater operation depends on very clean and uncontaminated fuel. Tiny dirt particles and contaminants can corrode, wear or jam the spinning spray head.
I suggest you service the heater - a thorough internal clean of the fuel system, clean the filter(s) and spray head, check and if necessary adjust the air pump regulator pressure and ensure the spark plug is clean, in good condition, is correctly gapped and the spark is constant and steady.
Your heater should then be ready for the coming winter season at the end of which, perhaps different summer storage arrangements would be advisable.
Oct 25, 2017 | Heating & Cooling
Unit initially when plugged in turns on for about 3 seconds then shuts down. What might be causing this? I'm using kerosene and tank is about 25% full.
I build houses and we use heaters alot in winter. What i would try first is in the back of the heater where it sucks air some have a crude filter . clean this . my experiance is that the unit is dirty and it starts blowing and hopefully lighting then whoosh goes out u unplug and wait five then plug back wham it fires agian for a nother three seconds. Its not anything much i recoment blowing air commpressor through it.
Feb 27, 2011 | Master Heaters B155DST
Monitor 2400 Kerosene heater service
Check your filter in the fuel line outside if you have one. Also check the strainer in the fuel sump.
Feb 02, 2010 | Heating & Cooling
Heater used once 3 yrs ago. Now wont start.
When the heater hums is the fan turning. If it is I would add more Kerosene. There is no shut off but the Kerosene is sucked out a tube from the top of the tank. This tube does not reach quite all the way to the bottom of the tank. Your heater should hold about 9 gallons if it is empty. A couple of gallons would give it plenty to run though. Let me know.
Jan 02, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Will not fire
this unit operates with a small air compressor at rear of motor. Remove the solid 1/8 inch plastic plug. install a low pressure gage. you should read around 5 psi
Feb 28, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Heater won't start properly
Remove the nozzle from heater and clean, be carefull around the ignitor.
Dec 31, 2008 | Desa International Reddy Heater R40 40,000...
Fan turns on starts blowing and a lot of smoke.
when you start it the smoke starts wright away it is not getting the right air flow takethe top part off and started see what it does if it stays running try to ajst. the fens ok .
Dec 26, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater-30-55,000 BTU Variable Logo
130 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
