SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
SOURCE: Dishwasher soap dispenser sticks
Mine dishwasher (a Maytag) did this also. At first it was becoming stuck because of the soap. My repair guy cleaned it and I switched to liquid soap and it worked great another 2 years then did it again. That time it was just wore out and had to be replaced. I was told it was no longer available but we found it here http://www.repairclinic.com/and our repair guy installed it. He was amazed because he had even called everywhere.
SOURCE: Dishsoap stays in soap dispenser
We had problems with soap remaining in the dispenser and dishes not getting clean when we used gel dish doap. We changed to the cakes of soap with a Jet Dry Power Ball in the middle, and now they clean fine.
SOURCE: Dry Dishwasher Soap Still in dispenser after wash.
so here it is...
get a screw driver (you may need a "star" head driver as well), get in there and take out all that you can and clean it (it all comes out pretty easily)...you will find a lot of undisolved soap and hard water build up...rinse it, scrape it, vacuum it...just get out as much as you can...keep note of how you took it apart so you can put it back together...then put 1/2 to a whole gallon of vinegar in and run a cycle (hi-temp if you have that option)...if it was like mine most of your sprayers were gummed up and the water just wasn't moving through the machine...
to avoid this problem...use half of what you have been using of your detergent...and only fill the "pre rinse" section if you are doing pots and pans....and then only fill that half way as well.
after that run a few cups of vinegar through on an empty cycle once a month...
whole job (not including the wash cycle) 1.5 hours...
SOURCE: Leaking water on floor in front of dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
