Question about SanDisk Cruzer Titanium 2GB USB 2.0 Flash Drive
The flash drive will not start up when I plug it in. I tried to go to control panel/add hardware and it give me a code 10 (This device will not start up). The light is on but the computer will not recognize it. Tried it on numerous compters with same results. Used it just yesterday and it was fine.
Posted by smcintos on
Mai Lor
    Genius:
  • SanDisk Master
  • 2,558 Answers
-Try this:
-Leave it plug in then go to my computer to see it's there or not.
-If not then type in search box " How to add New hardware"
then just follow trough the instruction to complete set up or recovery.
Good luck and enjoy
Mai
Posted on Jan 12, 2018
Dayton Computer
    Master:
  • 669 Answers
Flash drives are STATIC Drives with no mechanical functioning parts. This kind of apparatus can be shunted or discharged by electrical disturbances. For example, a static charge, somewhat like when you rub your feet on a carpet and touch a door knob "POP, you get a spark". So, if the flash drive receives an electrical discharge or it is pulled from the USB Port without properly ejecting it, it can render the flash drive dormant. The data will be lost and usually can not be retrieved. That is why you should always make a secondary back up of important data on another drive.
5 Related Answers
Anonymous
  • 1623 Answers
SOURCE: My flash drive will not operate when plug into my lap top.
Hello kjh87....
1) If you are using a USB cable with your device, check the cable to make sure it matches the speed of the device. Use USB 2.0 cables with USB 2.0 devices and USB 1.1 cables with USB 1.1 devices. Swap cables and check the device, if this does not work, proceed to Step 2.
2) Next, open Device Manager and look under the heading for USB Serial Bus Controllers. If there is a device with a yellow exclamation mark next to it such as USB Mass Storage Device. Double-click on the entry and check the Device Status. If the status shows something like
"This device cannot start. (Code 10)"
proceed to Step 3.
3) The easiest way to solve a USB error code 10 in Windows XP
is to follow the steps below to remove and reinstall all USB controllers.
A. Click on Start
B. Right Click on My Computer, click on Properties
C.Click on the Hardware tab
D. Click the Device Manager button.
E. Expand Universal Serial Bus controllers section.
F. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
G. Restart the computer, and allow the computer to reinstall the USB controllers.
H. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
For more information on Troubleshooting USB device problems, visit the Microsoft Support Article on this subject.
I hope this helps...
Posted on May 28, 2009
CoquiBiz
Juan Carlos Cabrera
  • 103 Answers
SOURCE: SanDisk Cruzer 4GB Micro - not recognized by computer
Well, Hello!
The Scandisk use two drives. One is a cd-rom emulation where the U3 utility resides and run. the other is the disk itself. Try the device on other computer and try other usb devices on your computer and analize the results. Note: On a Mac you only will see one disk drive.
Is your computer recognize other storage devices and you U3 disk doesnt work on other computer the drive is most likely to be corrupted. In this case you will need to install the uility from Sandisk to recover the functionality of your drive.
Posted on Jul 01, 2009
Anonymous
  • 3153 Answers
SOURCE: My flash drive wont do anything when i plug it to my computer.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 21, 2009
Anonymous
  • 1112 Answers
SOURCE: SanDisk 8GB Cruzer Micro U3 USB Flash Drive
Hello Niz: If the stick is still usuable try downloading launch pad this usually works if the memory chip is still viable, You can get the download wizard from this site.
http://www.sandisk.com/sandisk-support/driver-download-wizard
Posted on Dec 15, 2009
Jerry Keelin
  • 376 Answers
SOURCE: i have a 8gb Cruzer Flash drive, when i conect it
I have 4 just like it and I've never had this kind of problem (Windows XP SP3). Have you checked the USB port(s) in Device Manager to insure there's not a problem there? Try rebooting the computer with the drive plugged in. You can recover the data on it using a program like BadCopy Pro (or similiar) providing you don't do anything to overwrite or erase the files on it first.
Posted on Sep 09, 2010
I am plugging in my Maxtor 80GB external drive and the green light flashes but the device doesn't come up on my computer. The computer is USB 2.0 so it's not that! Please help, my course work is all on...
Go to Start, Settings, Control Panel. Once there, open Add Hardware. It will scan for any new hardware devices that have been plugged in, including through USB. If it fails to find your Hard Drive, don't despair, all you have to do is go through the list of devices it has listed. If your device isn't listed, chose the bottom choice, "add a new hardware device." First try to have it search for the hardware automatically. If that fails, install it automatically from a list. You might need drivers for the Hard Drive, so it would help to go to Maxtor's site before you begin and find the appropriate driver for your model of hard drive, so you'll have it on hand when and if it asks for it. Once that's done, your hard drive will be recognized and all of your data will be accessible. Best of luck, and if you need further assistance, just ask.
Why doesnt it show on computer when i plug it in
What kind of flash drive and computer are u working with? Let me know and I may be able to give u a more accurate answer. Try inserting another device in that USB port and check to see if ur computer is recognizing it in your device manager. Click on Start Tab then Go To Settings , Control Panel Then Click on System Icon , Then Click on the Hardware Tab and Click on Device Manager, scroll down to see if there are any yellow question marks or flags? Leave that Device manager window open and try to re insert your flash drive again and see what response u get?
1helpful
Code 37 on dvd drive
The Code 37 error may occur when the concerned device is not connected to the system correctly and when its driver is faulty. A code 10 error is common when you add or remove USB devices or video & sound cards to and from your PC. When these errors occur, you may receive the error message given below.
Windows cannot initialize the device driver for this hardware. (Code 37)
To resolve code 37 errors, first ensure that your device is properly connected to your system. For instance, check all the cables of your printer or check that your sound or video adaptor is properly seated in its slot.
Try to remove and reinstall the device, and run the Add New Hardware Wizard from the Control Panel to see if Windows detects and installs it. If this does not resolve the issue, then update the device driver by performing the following steps:
1. Open Control Panel and select System.
2. In the System Properties dialog box, select Hardware tab, and then click on the Device Manager tab.
3. Scroll down the Device Manager window and identify the faulty hardware from the list.
4. Right-click on the hardware and select Update Driver.
5. Follow the screen instructions to resolve the error.
If these steps do not resolve your error, then the problem might be with your device. Get it checked by an authorized technician.
1helpful
2answers
Hello kjh87....
proceed to Step 3.
A. Click on Start
Have the philips spc620nc webcam, installed all of it, and when i try to hook up camera i get an error code saying it cannot start code 10, this hardware will not install and my usb port does work, already...
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver see if this helps
if that does'nt help you can do a winupdate
before you try to reinstall make sure its removed from add remove in control panel
unplug the cam restart pc and run software don't plug in cam until instructed
if you still have a prob then
Error code 10 and 39
A Code 10 error usually occurs due to:
Missing device driver
Malfunctioning device driver
Incomplete device driver files
to fix it..........
updating the device driver for the faulty device
1st) To update the driver, select the System option from the Control Panel.
2nd) In the System Properties dialog box, select the Hardware tab,
3rd) select the Device Manager button.
4th) Scroll through the Device Manager window and identify the faulty hardware device.
5th) Right-click on this device and then select the Update Driver command. Next, follow the screen instructions to update the driver of the selected device.
Usb 2.0 10 GB Flash drive hard drive not being found
DVD DRIVE NOT BEING RECONISED
This is a solution for error code 41 but it may assist you with your problem.
A driver was loaded but Windows cannot find the device. This error occurs when Windows does not detect a non-Plug and Play device.
If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Good luck.
Laptop wont recognise dvd drive
Here is the explanation and solution for the error code 41:
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41) Recommended resolution
Good luck.
Computer does not recognize player (Mambo TouchFlix by Kaser Corp.)
if it doesn't create then you probably need to manually add the device. sounds like your plug and play is toggled off for the device. plug it in and go to your control panel and click printers and other hardware. then on the left side menu you should see add hardware. go there and the wizard should detect the device as recently added but not installed and gives you the option to install. let me know if this helps. and good luck
SanDisk Cruzer Titanium 2GB USB 2.0 Flash Drive Logo
Top SanDisk Electronics - Others Experts
k24674
Ekse
Mehandi Husain ...
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
