Hi deanocar,
Based onyour concern, I suggest trying the following steps:
1. Before you plug it in make sure the PSPis in USB connect mode.
--> Alsomake sure the Memory Stick PRO Duo has been formatted for PSP. If it's not thisis how you do it:
On themain menu, scroll all the way left to the "Settings" menu. Thenselect "System Settings." Then scroll to "Format MemoryStick" and press X.
2. Connect the PSP to your PC with a USBcable.
3.Press the "home" button on the PSP
--> atthe lower left of the screen you can see the home button.
4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP.
5. Press the "X" button, your PSPshould display "USB Connection".
6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F:
7. Click on the drive letter thatcorresponds to the PSP unit.
Hope ithelps,
Thank youfor using FixYa.
1. Connect your PSP with your PC using the USB cable.
2. Use your PSP interface and hit HOME button, and then go into "Settings". Here you will have to use the directional button to find "USB Connection"
3. Once the connection is made, you will need to check your PCs available drives. You can do this by going into "My Computer". Your PC should detect your PSP as and additional drive. It is not much different from using portable drive or thumb drives actually.
4. Click on your assigned PSP drive.
5. Create a new folder call "music" on your PSP drive
6. Select your MP3 music from your PC and drag it into your "music" folder on your PSP. Note that all this is done in your PC interface.
7. When all the desired MP3 are transferred, get out of the USB connection mode by pressing "O" on your PSP.
8. Find the music area in your PSP, and select your memory stick. Search for your "music" folder and you are good to go.
