Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
We have an Electrolux S/S side by side w/Ice&water though the freezer door. The water flow through the door has been inoperative for several months but the ice maker continued to work fine. Water pressure at the base of the Freezer door was good as there is a quick-disconnect of the tubing which when disconnected allows good water flow. Now the ice maker has also stopped getting water. You can hear the system pressurize when the ice maker calls for ice (when manually cycled) and when the water dispenser is activated, but water gets to neither now. Any ideas?
Posted by scollywh on
Anonymous
  • 277 Answers
Check and see if there is a built in filter pack inside the back of the fridge or it could possibly be that one of the lines has froze internally and or the open close valve at the water inlet inside has worn out
Posted on Jan 18, 2011
Electrolux ETE 4200 SB-R freeze fridge. freezer cold, but fridge wont cool. back of the unit sealed with only compressor (?) visible at bottom. Cant check fans, coils etc. Cheers Gary
That is not a good model number. Is it a top mount freezer or side by side? Generally in electrolux the freezer is what cooks the fridge, if fridge is not cooling, it could be several things causing it.
1. Damper not opening
2. Damper has ice build up
3. The return has ice build up
4. The freezer evap assembly is not defrosting to allow air flow.
5. The evap fan is not turning.
Aug 04, 2018 | Electrolux Refrigerators
Water dispenser line frozen, items freezing in fridge side. Freezer constantly running/blowing
Your freezer is what actually cools the refrigerator. The cool air enters from that spot on the top left of the freezer. Make sure that isn't blocked. It's sounds like the thermostat that controls the air flow from the freezer to the refrigerator isn't working or the air flow control device is stuck.
Either way if you can, unload and unplug the unit. This will do to things. First it will reset the circuits that control everything and secondly if the air flow control is frozen thawing out the refrigerator and freezer may free it up.
Feb 04, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Electrolux side by side E126ss55gso Ice and water control board will not respond to touch, Error codes of CE on ice and water, alarm will not shut off
You have a communication failure, check the wiring at the freezer door hinge and if it is ok replace the control beneath the unit if it continues replace the user interface as well
Sep 22, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Ice has formed in the freezer of my electrolux frostfree refrigerator & the lower compartments are not cooling. what do I do now?
Could be door has been accidently left open and now ice is blocking the air flow, try switching it off for at least 12 hours with door open to manually defrost ice. Also check that the fan inside the freezer is running.
Nov 02, 2010 | Electrolux Refrigerators
Water from the water dispensor not flowing anymore
Do you hear the valve opening at the back of the fridge click when you push for water?
If not ....it may need to be replaced.
If you do hear a click.....the water line may be frozen in the freezer door.
Open the door wide open for a while......1 to 2 hours and occasionally try the water.....cover the freezer compartment with towels to keep the cold in that area but not the door.
Aug 17, 2009 | Whirlpool ED5FTGX Side by Side...
Water leaking from behind ice chute door & freezes under ice bin
You will have to remove the unit and access the rear of freezer. Check that the filters are not plugged as well as drain.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana side by side with ice/water in the door freezer stops freezing about 8 yrs old
First of all the worst thing you can do is set your fridge on the highest setting even though it has it. That's live reving your car to the red line just because it has it. As far as your challenge is concerned, it sounds like a breach in the seal of the fridge or dispenser. Check to see if the ice despenser is closing properly after use and check the door seal to make sure it's closing tight when the door is closed. To do this, simply inspect it for any bad wrinkles, cracks, folds, etc. if none are visible close the door on a dollar bill and make sure it holds securly all the way around the door. I f it doesn't, the seal may need to be replaced and/or the door is warped. If you continue to have issues, post again, we will work this out.
Jan 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
No water or ice
sounds like your door swith is not working. it wont let water or ice flow when door is open (even when door is closed it is not making contact)
Jan 12, 2009 | Refrigerators
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Inoperative Ice Maker
FROM WHAT YOU SAYING LG HAS MADE YOU DO A SELF TEST ON THE ICE MAKER AND ITS WORKING FINE.YOU NEED TO CHECK THAT YOUR SECOND WATER VALVE AT THE BACK BOTTOM RIGHT CORNER IS WORKING OK THAT MIGHT BE YOUR PROBLEM.GOODLUCK/ MOHAMED
Sep 09, 2008 | KitchenAid Superba Architect KSCS25INSS...
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
354 people viewed this question
Top Electrolux Refrigerators Experts
Marvin
Marvin
Charles Tidwell
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
