Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Just bought panasonic th-42x20k, when turn on hear a clicking sound and then turn off, red light under screen flashing 7 times
Posted by najmuddin_za on
Anonymous
  • 21 Answers
Red light flashing indicates that "SC voltage is floating". I'd recommend replacing the SC, SD and SU boards. Also know as the Y sustain (SC), Upper and lower buffer boards (SD, SU).
I suggest you contact your local Panasonic Service Agent as parts are only available from Panasonic and are quite expensive.
Posted on Jan 18, 2011
Panasonic 50 inch plasma th 50px80ua tv won't turn on and red light flashes seven times
Hi Steve, The link below is a YouTube video showing a panasonic television with 7 red flashes, Also there's videos down the right side of the link that may help as well... I hope this helps............CHEERS..
Panasonic TC P50S30 review seven led flash
May 01, 2016 | Panasonic Televison & Video
My Panasonic TH-50PZ7OOU will not turn on. The red light on the lower left is on, but the screen is completely dark. pressing power button on both TV and Remote control gets no response.
Try to power it up with the remote control. When you hear the relay's click, see how many times the red light flashes. This will tell us what the fault is.
Apr 22, 2011 | Panasonic TH-50PH9UK 50 in. Plasma...
My 42" Viera does not
You have a power supply problem. The plasma is not igniting.
I am sorry that outside of checking a few things, there is no easy fix.
You should hear a distinctive CLICK within a second or two when you press the ON button. That is the power relay. If you do not hear a click, the power supply is not working.
After the CLICK, you should see the screen brighten slightly for a moment. Since your power light turns red, it sounds like the supply is malfunctioning.
If you have had the set for a while, and it is still under warranty return it. If the warranty is expired, repairing may be expensive. Only a technician trained in servicing your set can tell you for certain.
If it is brand new, do not even try and mess with it, exchange it.
Jan 29, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic CT32HXC14J Red Light flashes 6 times
tengo un panasonic th-50px80u tiene una raya negra de seis pulgadas el lado derecho de la pantalla como soluciono este problema.
Nov 23, 2008 | Televison & Video
TH-42PX80U
i have the same problem but i have 11 blinks
Aug 13, 2008 | Panasonic TH-42PX60U Television
Panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Dec 29, 2007 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
257 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
