Question about Kyocera Mita KM-2530 Laser Printer
We have a Kyocera FS1118. We used to send scanned images through email through our internal email server and it worked. However when we moved to an external email server and changed all the configurations like gateway etc.. we are having error Error (0x2102) pls help.
Posted by rsoodin on
Shawn
  • 200 Answers
I have the setup instructions posted, click on the link below and follow those instructions. If after following those instructions you are still having a problem feel free to contact me.
http://gfbm.net/selfhelp_kmacopier_scan_to_email_setup_command_center.htm
Posted on Jan 22, 2011
Guyscan you help me configure Scan to email from a Kyocera Copystar 250ci printer what settings will i look around to configure scan to gmail or other email clients
You need to find where to enter the settings for an smtp server. (simple mail transport protocol) Most internet service providers allow clients to use their smtp server. For instance, for Shaw in Canada to smtp server is mail.shaw.ca. Some will require authentication in which case you will need to have a valid account with that provider.
Jan 22, 2016 | Kyocera Office Equipment & Supplies
How do i connect to the scanner.I have this connected for the printer,now i need items scanned to send e-mail don't know how to do this
It all depends on how your set up is. If you are connected through USB, you will need to download the twain driver from the Kyocera website. Then you can utilize any scanning program that you wish to collect the document image.
If you are connected through ethernet, it's a little more complicated. The first choice you need to decide is what you want done with the document image after it has been acquired. There are three main choices: Upload to FTP server, Send to a folder on a computer through SMB, or email.
All three of these options are obtained through the Kyocera Command Center software installed on the printer. Point your browser to http://192.168.2.10/ and you can login. If it asks for password, the unit ships with password "admin00", so that should get you in unless someone changed it.
You can adjust the settings through this screen. Head over to the "scan" tab, and you can put in the information for whichever way you want it. If you decide on Email, you will notice at the bottom of the page a link to set up the SMTP options for sending the emails.
Another note with email: you will need to set up a DNS server in the TCP/IP section under "Basic" settings. If you don't have a DNS server on your network, you can utilize universal ones. I recommend using Google's DNS servers (8.8.8.8 & 8.8.4.4)
Sep 21, 2011 | Kyocera FS1128MFP AllInOne Laser Printer
When i scan to email, i get an error; "send error 2202" and the document is not sent to email. The Kyocera fs-1028mfp printer is connected to the LAN using a network cable.
Apparently there is a communication error between the printer mail server. Can you ping both reliably ? Is it an internal mail server ? If yes, can you ping the printer from it ? Did you try changing the network cable ? How about IP addresses ? Could there be a conflict ?
Cheers,
Franck Horlaville TAM Software
Sep 12, 2011 | Kyocera FS-1118 Printer
WorkCenter M118 it stop sending scan over email. Insted of sending it print the NDR with error E11202
Solution : Make Sure the SMTP (Mail) Server is an Open Relay Server or Uses POP-Before-SMTP Authentication The mail server being used must be an Open Relay server or use POP before SMTP authentication. If the mail server being used requires SMTP authentication, the scan to e-mail process will fail. The WorkCentre is unable to access the mail server when SMTP authentication is required. Contact your Internet Service Provider (ISP) or System Administrator for additional information.
NOTE: The WorkCentre was designed to send e-mail through internal corporate mail servers. In most cases, if using your Internet Service Provider (ISP) mail server, the scan to e-mail process will fail because most ISP mail servers require SMTP authentication to send mail. Contact your ISP for additional information.
Feb 24, 2011 | Xerox WorkCentre M118 Black and White...
Copystar CS-1820 Black and White Copier: need to scan a document to send as an attachment t...
You need to setup the email server setting through the command browser of the machine. open the explorer and type the ip address of the machine. under Email scanning setup the email server info and you will be fine.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
May 17, 2010 | Kyocera Copystar CS-1820 Black and White...
How do you scan a letter then email it to you?
Press the Send Key
Scroll to Destination
Scan to email
enter email address
start
You must be connected to an email server.
Dec 30, 2009 | Kyocera Copystar CS-1820 Black and White...
Kyocera FS1118 mfp
FS1118 scanning issue - this may sound like a long process but its easy...
Just create a folder called scans in your c:/ drive right click and share the folder
Go to the kyocera command centre (type the ip address of the machine into your browser, taking note your machine must be networked)
Once in kyocera command centre
Click on basic
on the left menu select address book, contacts
create a new contact and under SMB
only insert your computers IP address in the host field
and insert the file name scans in the path field.
Click submit...
Once complete go to your machine
insert a page to scan, select the send button
press the address key
select the contact you created
select ip address press enter
now press 2 on the keypad
press enter
press 2 again
enter again
and then press the green start button once complete..
The scanned document will appear in the scans folder
Aug 01, 2008 | Office Equipment & Supplies
Kyocera 2550 Scans but how do I OCR?
You can find documentation form Kyocera Printers here, though it barely mentions anything about their OCR feature:
http://usa.kyoceramita.com/americas/jsp/Kyocera/home.jsp
The OCR feature is only an image quality setting, producing a more black and white high contrast image rather than a grey scale image.
I'm using our Kyoceras to email the images to a server where "send mail" processes the image and runs OCRopus, an open source Google funded OCR project, to read information from the scan.
I'm finding there are many Virtual ReScan solutions, like Kyocera's OCR feature, VRS software produces OCR optimized images, though I haven't found an open source VRS project.
Jun 08, 2008 | Kyocera CS-2550 Black and White Copier
Kyocera Mita KM-2530 Laser Printer Logo
5,770 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
AAAA262430
Marvin
Marvin
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
