Cell Phones Logo
Posted on Jan 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Recieved new sim card,after old card was faulty.how do i activate if ive forgotten pin number
Anonymous
Level 2:
  • Expert 109 Answers
  • Posted on Jan 18, 2011
Anonymous
Expert
Level 2:
Answers
109
Questions
Helped
25022
Points
493
If you've received a new SIM card, it has a default PIN number that you can get from the person who issued you the SIM card, just call and ask the person who issued it. It is usually 0000 or 1111, but I do not recommend trying, since you'll need a PUK code if you miss PIN code three times.
If this helps, please rate. Thank you
What is the free imei unlock codes for a forgotten passcode?
There is no such thing as a free imei unlock code. If you need to unlock the sim in your iPad. (imei is connected to they Sim card) you can ask the provider to give you a new sim card with the same number. the new card has a new imei, new pin and new Puk.
1helpful
Ive forgotten my pin number
If you have forgotten your PIN or PIN2 number, kindly contact to your Network Service Provider to get it because PIN and PIN2 numbers do not relate with phone. These relate with SIM Card.
1helpful
2answers
These are my numbers 0796086761 and i need mt PUK please
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave' for today.
Subject: How to unlock a SIM card
Customer's exact description: these are my numbers 0796086761 and i need mt PUK please
Discussion: Problems of this type can be easily solved. Customer did not provide the name of the service provider.
Solution: Provide instructions for unlocking a SIM card
PUK Codes
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from AT&T to unlock your SIM card.
Since I don't know the name of you carrier, I'm using AT&T as an example. Most carriers use the same methodology though the wording may be different.
You can obtain your phone's PUK code from AT&T in one of these ways:
Take the phone into your carrier's retail outlet.
OR
• Log in to myAT&T online
• Use our Technical Support Chat.
• Contact Customer Care
To get your phone's PUK code online:
? Log in to myAT&T.
? From the myAT&T tab at the top of the page, hover over the Wireless link and select Phone/Device under the My Wireless Service heading.
? From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading.
? The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
Second Solution:
You can also do it without any assistance from anyone. However, be sure to read the following carefully because there are pitfalls. If you want to try to do it yourself, just click on the following link: Universal Software Solution for Unlocking a SIM Card
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below I've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing one's PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes.
The Final Solution:
The following methodology does not work for every phone. Perhaps you'll be lucky. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code)
** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Display Handset IMEI
*# 06 #
This was wordy but hopefully it helped you.
Ben
*# 06 #
Ben
Sep 11, 2011 • Cell Phones
2answers
Get me a new security code of nokia 7210
The PUK code is not related to the handset. It is associated with your SIM card. When you enable the PIN in your SIM card, every time you switch on your phone, you will be asked for your pin. At given number of tries provided by your mobile operator, that you have provided the wrong PIN (usually operators set it at 3 tries), then you came to the stage called PUK-blocked.
To unlock, you would need the PUK code of the SIM card. The PUK code is usually an 8-digit code. This PUK code should have been provided to you when you purchased your SIM card. Some has the PIN-PUK code printed in the card body of the SIM card, while some attach it as a separate print out. Should your operator failed to provide this PIN-PUK code to you, you would have to get it from your operator. Try calling their customer service. Just like the PIN, the operator as well could say how much tries do you have to successfully unblock the PUK of your SIM .
Mar 14, 2011 • Nokia 1100
SAMSUNG S5233 WHY THEMES IS NOT DOWNLAOD ?
Tired of memorizing new PIN codes? We show you how to change your SIM card's various PIN and PUK codes in less than 5 seconds.
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below we've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing ones PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
*# 06 #
<a href="http://www.5starandroid.com">Android Mobile</a>
My samsung B7722, first time insert sim card, after enter pin number, error massage came out "phone freeze, sim unavailable, please contact your service provider" how to settle?
Although most people remember their primary SIM PIN code, those othercodes - used for various verification purposes - are never to be foundwhen needed. Below we've included a set of short codes which, whenentered on a handset's standby screen, will let you easily change PINand PUK (short for Pin Unlock Code) codes - but keep in mind, they maynot work with all handsets and mobile operators.
More importantly, when changing ones PUK codesthere'll be no help to get from the mobile operator if the new codesare forgotten, so make sure to write any changes down alongside the oldPUK codes. Also, please note that the codes should be entered withoutthe spaces shown below.
Change SIM Card PIN
*# 06 #
Hi, ive got a silver n95 that will not send txts, it recieves txts and all otha funtions work ok
Sounds like you need a new Sim Card, you can get them anywhere for free either by popping into your nearest O2 shop or ordering them online. Once you get this, ring 202, this is the customer service hotline you need to ring to activate your new sim, you can also request to keep your old number here. You may have to wait 24 hours for your new sim to fully activate, but when it does you should be able to send messages again.
Hope this helped!
1helpful
I have an lg vu and i wanted to see what happens after the pin is gone 5 times now my screen just sayz puk blocked please need help!!!!!
If all else fails, you can use cellunlockstore.com for $1.99. Try the instructions below.
To change your SIM card's various PIN and PUK codes:
Change SIM Card PIN
Jul 19, 2009 • Cell Phones
4answers
Puk code
You will need to contact your service provider along with your mobile and your connection reciept to recieve the PUK code.
Thankyou
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
