Question about Samsung SGH-F400 Cellular Phone
I am having a battery back up problem with my samsung sgh f-400, the battery lasts for only for 2 hours after charging it for full. I have replaced 3 to 4 batteries, but there is no result, And the original battery is very costly, so i was trying the compatibility with other local market batteries.
Anonymous
  • 109 Answers
As for the reviews, your phone's battery is its biggest issue - it has a very short lifetime. It shouldn't be 2 hours, though. What you can try is lower down the brightness settings. It will increase the battery life, but probably not as much as you would like to. If you have already tried new batteries in it, try changing a charger. There are some "speedy" chargers that do not fully charge your battery. If it also doesn't help, the only option you have is to buy some other phone.
If this helps, please rate. Thank you.
Posted on Jan 18, 2011
Anonymous
  • 327 Answers
The problem isn't the battery.
the problem is from "supply center" of your phone.
i recommend you to completely change your phone.
because cost of repairing the phone in a gurantee center (if the warranty has expired)
is higher than cost of buying a new one.
Anonymous
    New Friend:
Its better to change phone software with updated one..
Posted on Aug 14, 2011
Battery charging
Depends on how much the battery is in use, and how much battery life is left.
If it's relatively new (3 years old) and fully empty, it could be full by 2 hours - 2 h 30 min. If it gets really hot before that time, it's full by then.
Mar 06, 2014 | Konica Minolta Dynax 5D / Maxxum 5D...
Hi, I have samsung SGH - X700, my phone gets switched off automatically when i speak for 15-20 min over the phone. When i put for charging, it shows full charged in 30 min.. Could you please...
The problem is with the battery. The battery life is down.
My advice is that you purchase a new battery from a recognised store.
When you have done that, before you use the phone, charge the battery fully. Also, ensure that the supply of power is steady.
In addition, to sustain your battery life, once in a whlie, like every 2 months, fully discharge then fully recharge your battery.
This should make it last longer.
Hope this helps?
Success.
May 15, 2011 | Samsung SGH-X700 Cellular Phone
Samsung d900 . battery run on half an hour during call and if it is sleep mode then till 4 hours only
Please check the adapter voltage and the charging of the battery when placed for full charging. Once the charging has confirmed to be full remove and try once again to see if the phone indicates. Now clean the terminals and connect. If the battery does not last , it is possible that it must be replaced. Please confirm with a battery from a friend and buy ONLY the original with warranty.
Apr 26, 2011 | Samsung SGH-D900 Cellular Phone
My samsung sgh a777 gets hot when I charge battery and my new full battery last only 6 hours. Thanks.
hi there!
battery life actually depends on how much you use the phone. you'll find it on the manual that you have, (product specs). age of the phone shortens the battery life aswell. its also normal for the phone to heat up when we're charging it (but make sure its only warm and not super hot). none original chargers (imitations, local) can make the phone too hot too. so first things to check would be these, but if you're using all original parts for your phone, and if the phone is not even a year old, and you think its too hot when being charged and you're seldomly using it for calls or internet in a day, then bring it to a samsung shop so that they can replace it for you ;)
Apr 07, 2011 | Samsung SGH-a777 Cell Phone
My Samsung SGH-t819 Phone turned itself off, won't come back on.
your battery in your phone is worn out.
go to your local cell phone shop and buy a new one..
charge it up and your set
May 23, 2009 | Samsung SGH-t819 Cellular Phone
Samsung charging problem
If very well could be the charging port. Have you tried a different charger?
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
For more information and links to the parts check the following link below.
Samsung SGH-D900 charging problem repair
May 13, 2009 | Samsung SGH-D900 Cellular Phone
Samsung sgh a707 battery problem his stand by time is only 3 hour and talk time is 30 min only
sounds like you need a new battery...also when you buy the new battery..make sure you charge it for a full 24 hours so that way it keeps it's memory and charges to it's fullest in the future charges.
Feb 11, 2009 | Cell Phones
No charge
It very well could be the charging port. As for getting samsung to repair for free, willnot happen. As long as it lasted through the warranty period they are satisfied with the design
With a bad charge port, You have 3 options.
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay.
Samsung SGH-D900 Broken Charging Port Repair
Jul 24, 2008 | Samsung SGH-D900 Cellular Phone
Samsung YP K3 only lasts for 2 hours
1. totally discharge the battery so it wont come on.
2. Charge the battery fully
3. Reset the player
Now check how long the battery lasts. If it is still 2 hours there is a problem with the battey and you will need to return the player.
Oct 29, 2007 | Samsung YP-K3 MP3 Player
Samsung e900 - battery life
replace the mobile phone charer and then try
Sep 07, 2007 | Samsung SGH-E900 Cellular Phone
Samsung SGH-F400 Cellular Phone Logo
Top Samsung Cell Phones Experts
Michael Thomas
Michael Thomas
Dan Webster
Dan Webster
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
