Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
Posted on Jan 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an om-22 oil miser and am using it for 2 months. As soon as it turned 15 degrees outside the heater would not run. It says EE-22, but I cannot change anything on the front, nothing works. nothing moves, just om-22 It is a new stove, good oil, and I need heat. Can you help me?
Anonymous
Level 3:
  • Master 674 Answers
  • Posted on Jan 19, 2011
Anonymous
Master
Level 3:
Answers
674
Questions
0
Helped
284358
Points
1926
EE 22 means it failed to light for 3 tries in a row. You have to unplug the heater for at least 30 minutes to reset this code. I don\'t know how cold it was before, but if this is the first time it has dropped below freezing I would suspect water in the fuel barrel or filter. Check the filter. You can also remove the line from the barrel then open the valve to see if any comes out. Catch what does come out so you can put it back in the barrel. Let me know what you find or if you need more help.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 15, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1434
Points
It might be good idea to check on the flame sensor. Its that wired with white wire attached to your fire chamber. Make sure that the sensor is not covered with soot like it happened to me. Remove the two silver screws and gently pull it out. I used a fine emery cloth sandpaper to clean and it fired up and stayed on without giving me the code ee22 anymore. I guess the flame sensor was just not seeing the flame when it came on. Don't forget to unplug the system for at least 30 minutes to have the code reset. It may take you the whole 30 minutes to disassemble, clean, and reassembe the flame sensor.
Please can you help with all the torque settings for the cylinder head on Hyundai Accent 1.5 1995"
Nissan Frontier, Xterra 1998-05
Torque Specifications
Fig.
TORQUE SPECIFICATIONS
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1998 2.4 (2389) KA24DE
1A Step 1: 22 ft. lbs.
2B 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
4C The cylinder heads and the lower intake manifold are installed together
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1999 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 3.3 (3277) VG33E
1A The cylinder heads and the lower intake manifold are installed together
3C Step 1: Tighten the cylinder head bolts to 22 ft. lbs.
4D Step 1: Tighten the connecting rod bearing bolts to 10-12 ft. lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1998 KA24DE
1- Step 1: 22 ft. lbs.
2- 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
3- The cylinder heads and the lower intake manifold are installed together
4- 10-12 ft. lbs. +60-65 degrees
5- Step 1: 72 ft. lbs.
6- Step 1: bolts 11-22 19 ft. lbs.
7- Step 1: 20 ft. lbs.
8- Step 1: 31 ft. lbs.
9- 83 inch lbs.
10- Stud bolt: 11 ft. lbs.
11- Step 1: 72 ft. lbs.
12- Bolts: 17-24 (M8) 16 ft. lbs.
13- Step 1: 33 ft. lbs.
14- Intake manifold collector:
15- Intake manifold:
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1999 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2000 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2001 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2002 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2003 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2004 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2005 QR25DE VQ40DE
9- 83 inch lbs.
Main Bearing Torque Sequence
Fig. Main bearing torque sequence-2.4L engine
Fig. Main bearing torque sequence-2.5L engine
Fig. Main bearing torque sequence-3.3L engine
Fig. Main bearing torque sequence-4.0L engine
Heat pump not keeping up to set temperature on thermostat but never drops below 63 degrees whens its 20 degrees outside.
It may be getting low on refrigerant due to a small leak. I'd have it serviced soon. When running at less than peak efficiency it will much more often switch on the heat strips and they are not cheap to operate.
Reading says EE 2 what does this mean
Hi Sandra, EE 2 means that the heater did not ignite. There could be several causes. First let me ask, did the heater make a ticking or thumping sound before you got the EE 2? If so that means the fuel isn't getting to the fuel sump. It could be caused by an air bubble in the fuel line, a clogged filter at the tank (if you use an outside tank), or a clogged fuel strainer in the fuel sump. EE 2 could also be caused by a bad igniter. Did the heater light at all? If it did then the igniter is good. If it didn't the easiest way I have found to check the igniter is to use a clamp on ammeter or use a multimeter to check the resistance of the igniter. Another cause is a dirty flame rod. If the heater lit then went out I would suspect this. It can be cleaned with some steelwool or fine sandpaper. Let me know what you find or if you need more info.
3helpful
Turning up the bar oil?
An “OM, 455e Rancher, 455 Rancher, 460 Rancher, 2009-09, EN, FR, ES” Follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-49.pdf
An excerpt from page 38 of the above OM follows (forcing it may render it inoperative):
Adjustment of the oil pump
Adjustments are made by turning the screw using a screwdriver or combination spanner.
The machine is supplied from the factory with the screw set to position 2.
Turning the screw clockwise will reduce the oil flow and turning the screw anti-clockwise will increase the oil flow.
Recommended settings:
• Bar 13"-15": Position 1 (full CW)
• Bar 15"-18": Position 2 (center)
• Bar 18"-20": Position (full CCW)
These recommendations apply to Husqvarna’s chain oil, for other chain oils increase the oil flow by one step.
WARNING! The engine must be stopped when making adjustments.
All OMs and IPLs can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
HEater is heating outside but not blowing warm air thru the vents inside the house. May blow air for 10 mins but then stops. I have the temp. set at 76 degrees but it is 48 degrees in my house right now.
sounds like you may have some restriction in the heater or overtemp sensor is kicking out to soon, clean everything thourghly, check fan and oil bearing, check safety circuits in furnace wiring, refer to owners manual trouble shooting guide
OM 22 Toyostove shuts down with EE2 out of fuel code but it has fresh kerosene and a clean flame rod sensor. OM 22 is same as Laser 30 except it can run on fuel oil.
Did you check to make sure all fuel valves are open, specifically the safety valve on the back of the machine? The stem should be sticking up if this valve is open. Following that, make sure you have reset the float in the fuel feed by pushing the red button on the right side of the machine.
J
1helpful
Monitor 41 20 years old rebuilt 3 years ago. out of fuel
Hope you got this fixed. Sounds like you were having fuel flow problem.
5helpful
Looking for the torque specs for 1998 chevy astro van?
1998 chevy astro 4.3 v6 torque specs include :
* foot pounds *
balance shaft (if equiped) gear bolt = step 1 = 15 ft.lbs. step2 = additional 35 degrees.
camshaft sprocket bolt = 18 ft. lbs.
connecting rod cap = step 1 = 20 ft. lbs. step 2 = additional 70 degrees.
crankshaft damper bolt = 74 ft. lbs.
crankshaft oil deflectorbolt/nut = 27 ft.lbs.
cylinder head bolts = step 1 = 15 ft. lbs. step 2 = additional 73 degrees. (tighten in sequence)
exhaust manifold bolts = step 1 = 11 ft. lbs. step 2 = 22 ft. lbs.
flywheel bolt = 74 ft. lbs.
main bearing cap bolts = step 1 = 15 ft. lbs. step 2 = additional 73 degrees.
oil filter adapter bolt = 15 ft. lbs.
oil pan bolt/nut = 18 ft. lbs.
oil pump bolt = 66 ft. lbs.
rocker arm with press in studs = 18 ft. lbs.
rocker arm with screw in studs = 19 ft. lbs.
valve lifter retainer bolt = 12 ft. lbs.
water pump bolt = 33 ft. lbs.
* inch pounds *
balance shaft retaining plate bolt = 106 in. lbs.
camshaft retainer plate bolt = 106 in. lbs.
front cover bolt = 106 in. lbs.
intake manifold upper = step 1 = 44 in. lbs. step 2 = 88 in. lbs.
intake manifold lower = step 1 = 27 in. lbs. step 2 = 106 in. lbs. step 3 = 133 in. lbs. ** (tighten bolts in sequence)
thanks for your vote !
3helpful
Toyostove Laser 30 has error code EE 22
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Top Rinnai Heating & Cooling Experts
Paul Carew
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
