Question about Tissot T Classic Seastar II T55.8.283.11 Automatic Watch
Bought a 1970s tissot automatic seastar watch and was ticking for two days the just stopped. Have tried winding but won't work. What is most likely the problem?
Posted by mel_sanders0 on
David Tolond
    President:
  • 2,501 Answers
A self winding watch will run for 2-3 days if it is not worn (they thrive on being used) and it sounds as if you have not been using it; is this the case?
It could be that the winder does not operate on the spring (some watches don't), so to wind it up you need to activate the self winding mechanism.
You can do this by gently swinging the watch from side to side for a few minutes. This will simulate the normal operation when it is being worn.
If you continue to have trouble with it stopping, it could be that it needs cleaning. I had a similar problem with a watch I had some years ago.
Posted on Jan 18, 2011
Can not regulate my tissot visodate seastar automatic
the problem is the air spring on the balance wheel it can be 1 or 2 things wrong spring stuck together with oil spring got crossed or if it's been neat a magnet, needs jeweler repair shop
Mar 15, 2013 | Tissot T Classic Seastar II T55.8.283.11...
The tissot visodate watch is automatic not battery driven.
I would not wind the watch manually. I also have a Tissot. If you cannot wear it often enough to keep it going, you can purchase a watch box that is made for self-winding watches which will turn the watch periodically in order to keep it wound.
Oct 19, 2012 | Tissot Visodate Automatic Leather Mens...
Do tissot make a automatic 100m sapphire date T354071105100 with a blue face Ken
Yes but there are a lot of fakes out there.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Tissot Diver Seastar 660 Steel Large...
I was given a Tissot Seastar and I know nothing about it or if it's worth fixing. It has a 17 jewel automatic movement which works fine.It also has the day and date. The movement number is 14190996 and the...
If it is the eta 2824-2 model. When you say the hands don't turn, I take it it does not work? its an automatic so needs wrist/ hand movement to wind the rotor. You can manually wind the watch by simply turning the crown (without pulling the crown out) Try doing this first.
Apr 30, 2017 | Tissot Watches
Tissot Seastar 1000 Does anyone know of a source
Tissot is Swatch. They do not sell parts! You need to contact the company OR where you purchased the watch.
http://www.tissot.ch/?mod=stores&action=search&search=&regions=2&countries=195&countryregions=&option=cs
Jan 14, 2010 | Tissot Diver Seastar 1000 Auto Steel Large...
How do I wind my Tissot visodate seastar automatic
Are you sure it winds? They also make battery operated watches! :-)
Jan 12, 2010 | Tissot T Classic Seastar II T55.8.283.11...
Tissot T Classic Seastar II T55.8.283.11 Automatic Watch Logo
411 people viewed this question
Top Tissot Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anonymous
Level 1 Expert
Are you a Tissot Watch Expert? Answer questions, earn points and help others
