Infinity US-1 Main / Stereo Speaker Logo
Posted on Jan 18, 2011
Do not know how to connect my kappa 60.5cs to my pioneer cd player do they have to go through an external amp?what do i do with the power plugs on the oppisite side why are there 2 per speaker
Anonymous
Level 1:
  • Contributor 41 Answers
  • Posted on Jan 18, 2011
Anonymous
Contributor
Level 1:
Answers
41
Questions
0
Helped
16023
Points
90
You need to run RCA cables from the CD player to the CD or AUX input on your amp / receiver unit. If you have a standalone amp, you need some way to control the volume. Basically, if you have a volume control on the front of your amp, you're OK. If not, you should also have a preamplifier that the CD player feeds first.
From the amplifier, then, a single pair of speaker outputs feeds a single pair of inputs on your speakers. The reason for two jack sets on the speakers is for "bi-wiring" or "bi-amping", not necessary for basic stereo reproduction.
So -
CD red/white RCA out -> preamp/receiver red/white CD/AUX input. Amp speaker output (red + / black -) to one red/black input pair on the speakers. An input on the speaker is side by side...
Keep the red to red, black to black when connecting the speakers, or you will wind up with poor sound and weak bass.
How to hook up a pioneer supertuner iiid
Pioneer DEH-1500 CD Receiver
Wiring Color Code:
Yellow
To terminal always supplied
with power regardless of
ignition switch position
Red
To electric terminal controlled by ignition switch (12 V DC)
ON/OFF
Blue/white
To system control terminal of the power amp
or Auto-antenna relay control terminal (max. 300 mA 12 V DC).
Black (ground)
To vehicle (metal) body
To speakers:
Grey = right front (+)
Grey/black = right front (-)
White = left front (+)
White/black = left front (-)
Violet = right rear (+)
Violet/black = right rear (-)
Green = left rear (+)
Green/black = left rear (-)
RCA connections go to external amp:
Red = right speaker
White = left speaker
This is the basic layout for most all stereos. The ones that have an orange or orange/white, this is the illumination wire.
Good luck.
SUBS WONT TRUN ON
Hello fresttadefjm,
There are no subwoofer settings on the Pioneer DEH-2800MP.
You need to check the external power amplifier and the connections from the Pioneer and from the sub(s). If everything is plugged in and wired correctly, check the amp fuses, both on-board and the main power fuse (located in the amp positive lead usually near the vehicle battery).
Hope this helps.
1helpful
Help with ipod connection to cd player
You must use 1 of 3 methods to connect your iPod
1. FM modulator to wirelessly broadcast on a low FM band
2. iPod 3.5mm male/male direct connect cable.
3. iPod USB connection - with Pioneer iPod adapter module.
The direct connect 3.5mm port is on the back of the unit. One plugs into the radio - one plugs into the iPod headphone port.
Click HERE for your owners manual in PDF format.
CLICK HERE for the installation manual
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
My cd player does not have an external amp wire but has amp connect jacks how do i hook it up to my amp?
You should plug your RCA's from your amp to your radio output. Then you should take the blue power wire for the amp and splice it to the blue wire on your cd players wiring harness. The blue wire is for an automatic antenna or for 12v current for a amp.
2helpful
No Audio when disconnect from external amp and hook to speakers
In a radio like your Pioneer and all similar units there are always a pre-amp circuit that feeds a power amp circuit,In some players there are more than one pre-amp circiuts. It is possible and highly probable that the power amp circuit in your Pioneer is shorted, so you still get some audio output , but very little. I believe this is your problem and I suggest that you bring it to a repair shop for an estimate or replace the unit. Good luck and please rate this answer, Thanks.
Pioneer indash stereo/cd player DEH-7500MP,no internal amp output
some cars have internal amps for the speakers try connecting the remote wire it's the blue wire with a little white on it worked in my moms van.. if that does not work try testing it with a speaker from your house
Turn on aux. on Pioneer DEH-P960MP
Hit source button until you are in aux mode... then plug in your external music source to the front 'aux in' with 3.5mm line Jack cable. You should be able to play and control from y he external equip.
Wiring my tuner-DEH-1800 to Amp GM-5300-T into my 4 speaker system.
In most head units as in your case the Pioneer DEH-1800, there would be 2 RCA female jacks at the rear of the unit. These are your OUTPUTs.
While in most amps including your GM-5300-T, there would similar RCA jacks which would be your INPUTs.
You need to connect the output to the input using an audio cable terminated at both ends with RCA plugs. Further you need to connect the remote trigger on from the head unit to the remote/external amp to switch it on.
A more comprehensive connection diagram is available at page 6 of the GM-5300T Manual which may be downloaded from here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
2answers
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
xxxxxx xxx
john h
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
