Lionel 40 Watt Transformer Train Set Track 624253 Logo
Question about Lionel 40 Watt Transformer Train Set Track 624253
Is lionel 40 watt transformer from toy train enough power to run a dual motor larger train engine it just lites up and sputters
Posted by hodgewild on
  • Anonymous Jan 18, 2011
    If the motor is trying to draw more current than the transformer can supply, the motor won't run and damage can occur to the transformer. If this is a newer transformer (looks like it), the green light should flash, and the transformer will eventually shut off, if the motor is drawing too much current. Does the light flash at all?
  • hodgewild Jan 18, 2011
    yes the green lite does flash and transformer shuts down. Do i need to purchase a higher wattage transformer for these larger dual motor train engines like a 150 to 400 watt transformer.
Anonymous
    New Friend:
    Problem Solver:
  • 13 Answers
Need a larger out put transformer 90 watt or greater....
Posted on Nov 20, 2011
Traindoc
    New Friend:
  • 38 Answers
It would depend on what engine you're trying to run. The 40 watt transformer's circuit breaker will trip off if you put too large of an electrical load on it. If the engine light stays on while it sputters, the track or the engine's motor and electrical pick-ups may need cleaning. Older engines that haven't been run for a while can get stiff. Your engine may need some lubrication.
Posted on Jul 23, 2011
Led blinks when train put on track
I am assuming you are using the Lionel CW80 power source. If so, the blinking light might indicate a partial short or a problem with the motor. The reason I believe that is that the CW80 has an internal fuse, which will blow for near shorts/shorts. A stalled motor i.e stuck drive gear, can cause excessive power drain although not enough to blow the internal fuse and also cause the engine not to move. Also, If the engine has the neoprene belt on one of the drive wheels it might have come off and is jamming the running gear or wheel. I believe the Polar Express only has one neoprene belt.
Lionel legacy will not run more than 2 trains
see pages 44 & 45 of attached pdf to figure out your power requirements for all locomotives, lamps/light bulbs & accessories.
compare total needed to power output of your transformer, if total is less that output of transformer, clean wheels, roller pickups & track.
if total is greater than output of transformer, you need more power/larger output transformer. lean wheels, roller pickups track.
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
My 1941 Lionel train stops getting enough power to run all the way around the track. Voltmeter says 15 volts around all track and transformer says 15 volts. How do I test engine?
If your sure the loco contacts/wheels are clean and the track is ok then remove the loco bodywork and check the motor. You can apply a 12v supply directly to the motor contacts to test if it's running ok. If it does run ok then suspect and clean the brushes and associated connections. If it does not run try moving the motor armature manually. If it is stuck it is probably time to replace it. If it moves apply a light machine oil and test again.
How often should tracks be cleaned. Engine slows down after running for a while
It depends upon how much you run your trains. Run your finger or clean cloth on the rail. If you see a dark mark your tracks need cleaning. You can also run another set of wires from the transformer to the spot on the track furthest from the transformer. You can even run a third or fourth equally spaced apart if you have large loops and long and heavy trains.
I am using a standard 80 watt transformer (not command control), but the rail sounds do not work on this unit at all. I have checked the on/off switch and played with the volume, but still no sounds. At...
Many of the MTH Protosounds 1 and 2 and Trainmaster will not work with the Lionel CW-80 electronic power source. The output waveform is so non-like sinusoidal. The electronic sound systems will not usually respond to this waveform and when they do, the sound will be garbled. Use another power source.
Can I use the cw-80 transformer on any Lionel train set from year 1948 to the preasant , thanks George
You should be able to. The Lionel transformers all put out AC power, not DC and many Marx and American Flyer transformers will work too. The real question is total amount of power being drawn and whether or not you have the wattage to match your engine and accessories. With the CW-80 though, it should put out plenty. I run my pre-war 1666E engine pulling a full compliment of metal cars with no problems using a CW-80.
3 year old Lionel 4-4-2 (road number 8632) that will not run on antique track. Does anyone have any insight into whether this locomotive needs a digital power source or if it would have an issue running on...
you may have to use a Lionel transformer for this because some older trains worked on AC current not the DC current that this train uses
Jan 02, 2011 • Toys
1helpful
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
2helpful
2answers
Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Top Lionel Crafts & Hobbies Experts
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Carolyn Rogers
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
