ASUS Netbook Logo
A
Anonymous Posted on Jan 18, 2011
I have a netbook 7"
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jan 18, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
1183
Points
31
Restart your netbook
when it begin open click f8
it will give you options
choose save mode then click enter
it will open as administrator
when it open
open run window
type "cmd"
click enter
will open dos
type net user
i will give you all users in your system,
chose your account name as example your computer name is lime
ok
then write it to reset password in this account
net user lime
then enter
restart your computer it will open without password
How do I hard reset my Craig clp281?
Forgot lock pattern on android? Here's a way to reset it.
Enter wrong pattern 5 times and wait for 30 seconds.
Select "Forgot pattern" and enter your gmail account username and password.
Make sure you use the same account that was used to activate the tablet and double check the
password by logging in to that Google account in a browser on laptop or PC
If you don't have access to the original Gmail account, you will need to do a hard reset and
loose your settings and apps on the Netbook. The data on the memory card will not be wiped
though.
If all else fails...
tip
Lost Acer Windows 7 Logon Password?
The netbook is redefined with the arrival of the Acer Aspire computer and many people like it. Most of them intall Windows 7 Operation System. As you know, a logon password should be created to protect your Windows 7 user account. Sometimes, you <b><a href="http://www.windowspasswordsrecovery.com/forgot-windows-7-password.htm">lost Windows 7 logon password</a></b>, how to reset it on your Aspire laptop? E.g. <b>Acer Aspire One</b><a href="http://www.windowspasswordsrecovery.com/images/knowledge/lost-acer-windows7-password/acer-aspire-reset-windows7-logon-password-big.jpg"><img src="acer-aspire-reset-windows7-logon-password.jpg" /></a> <br /> <b>Notes:</b> <br /> <b>1.</b> If you don't have created a password on Acer netbook, you may be insterested in this tutorial: " <a href="http://www.windowspasswordsrecovery.com/create-a-windows-7-logon-password.htm">How to Create A Windows 7 Logon Password?</a>"<br /> <b>2.</b> If you forgot Windows 7 User password, you have 2 methods to retrieve it. One is below steps, another is this guide: " <a href="http://www.windowspasswordsrecovery.com/reset-windows-7-password.htm">Reset Windows 7 Password With a Password Reset disk that was created before you forgot Password</a> "<br /> About Acer Aspire Aspire is a series of personal computers by Acer Inc. aimed at the casual household user or for small business use. The Aspire series covers both desktop computers and laptops. Acer developed the series in order to cover from essentials to high performances.<br /> How to Reset Windows 7 Password on Acer Aspire? Just follow below steps to recover your Acer PC password, it will only take your few minutes.<br /> <b>1.</b> Login another computer that you have access, download <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Pro_Trial.exe"><b>Windows Password Recovery Tool Professional</b></a>, install and run it.<br /> <b>2.</b> Burn a Aspire laptop password reset disk, you can use CD/DVD or USB Flash Drive. I recommend USB if the locked Aspire laptop supports it.<br /> <b>3.</b> Connect the password reset disk with the locked Acer computer, Press "Del" while the computer just start, then <a href="http://www.windowspasswordsrecovery.com/getting_started/bios_usb.htm">go to bios setting to boot computer from the USB Flash Drive</a>, reboot the computer to load the program. <br /> <b>4.</b> Select the user account which you lost itslogon password, click "reset" button to begin resetting password.<br /> <b>5.</b> A message box will pop up, just click "Yes", then the user's password will be hacked.<br /> <b>6.</b> Disconnect the password reset disk, and reboot Acer PC. You will login Windows 7 without password.<br /> Screenshots on resetting Aspire Computer Password <a href="http://www.windowspasswordsrecovery.com/images/knowledge/lost-acer-windows7-password/burn-aspire-laptop-password-reset-disk-big.png"><img src="burn-aspire-laptop-password-reset-disk.png" /></a> <a href="http://www.windowspasswordsrecovery.com/images/knowledge/lost-acer-windows7-password/reset-lost-acer-windows7-password-big.png"><img src="reset-lost-acer-windows7-password.png" /></a><br /> Finally <b>Acer Windows 7 Password Recovery</b> is not a difficult thing, you don't need to become a expert. Above experiment was carried out under Windows 7, but this tool also supports Windows XP, Vista, 2008, 2003, 2000.<br /> Tips: <b>1.</b> You can <b><a href="http://www.windowspasswordsrecovery.com/create-windows-7-password-reset-disk.htm">create a Aspire Password Reset disk</a></b> before your lost Windows 7 Account password.<br /> <b>2.</b> Keep in mind that this software can be only used on your own computer, never try to use it to hack other person's login password without permission. Otherwise, you will be caught by police.<br />
on May 23, 2011 • Computers & Internet
tip
Reset Windows 7 Password With Own Created Reset Disk
It is easy for you to create a password on Windows 7 to protect computer data. At often as you might forget Windows 7 password, which may result in serious data loss. In reality, forgetting Windows 7 password is not a big problem as long as you create a Windows 7 password reset disk in advance. A Windows 7 password reset disk can help you easily reset Windows 7 password when you are locked out of computer.
Part one: Create Windows 7 password reset disk
Before creating the password reset disk, please insert a USB flash drive or floppy disk in your computer.
1.Click Start button to select Control Panel.
2.Click on User Accounts and Family Safety, and then click on User Accounts.
3.Click on Create a password reset disk on the left of the following screen.
4.Click Next when the forgotten password wizard welcome screen appears.
5.Select your target device to create the Windows 7 password reset disk.
6.Type current user account password.
7.Click Ok when the password reset disk is created.
8.Click Finish when the completing screen comes up.
When the Windows 7 password reset disk is created, a file named userkey.psw will appear on your USB flash drive. Please remember to place the USB flash drive or the file in a safe place. Anyone can use it to reset your Windows password with it if he can get physical access to it.
Part two: Reset Windows 7 password with password reset disk
When you forgot Windows 7 password and locked out of computer, you can take out of the password reset disk to reset Windows password. Plug your password reset disk in computer, and then follow the below steps for Windows 7 password reset.
1. Log on your computer with the target Windows account.
2. Enter a wrong password in the welcome screen password box, and hit Enter.
3. Click OK when the message that the user name or password is incorrect comes up.
4. Click on Reset password on the following screen.
5. Click Next when password reset wizard welcome screen appears.
6. Select the target password reset disk and enter Next.
7. Enter and confirm your new Windows password and click Next.
8. Click Finish to close the wizard.
9. Log on Windows 7 with the newly reset password.
If you forgot to create Windows 7 password reset disk before locked out of computer
A windows 7 password reset disk can really save you a lot of trouble when you forgot Windows 7 password and locked out of computer. So don't forget a password reset disk before locked out of computer. If you forget to create Windows 7 password reset disk, you can use Windows Password Breaker Professional to help you reset lost Windows 7 password. This safe and reliable Windows password recovery software allows you to burn a bootable CD/DVD or USB flash drive to rest lost passwords for Windows 7/Vista/XP/NT and Windows Server 2008/2005/2000. You can log on your computer again within 5 minutes with this tool.
on Oct 29, 2010 • Computers & Internet
I forgot my password to log onto microsoft windows ce on my netbook and now i can use it at all. How can i recover my password or reset everything?
There are three options that you can follow: Option 1:use password reset disk if you have made one. this is an easy way to reset just follow the instructions. Option 2:use command prompt to reset Windows 7 password, but you should login your Windows as administrator Option 3:use third party program to reset lost windows 7 password.Windows Password Recovery Tool is a good choice that you can try, you can reset the lost password in several minites
2answers
Forgot admin password cannot how to reset admin password gateway lt2104u
Look on Ebay for a password reset disk. Many vendors on Ebay sell a bootable "linux" disk that you boot from and then you can edit your password file on Windows. I have versions for XP/ Vista.Windows 7.
Be sure to get one that works for your version of windows. You must set the BIOS to boot from the CD drive first for this to work. About $5 to $10 for the reset disk.
Regards,
Dennis
7helpful
8answers
Forgot my password to my hp mini window 7 starter
I know a software can hack HP password windows 7,and I used it before,my friend recommended it to me,it is easy to use,and I do it by myself.It seems called Windows Password Recovery Tool 3.0.You can have a try!
For more detail steps on how to reset password on hp laptop, please feel free to visit: http://www.windowspasswordsrecovery.com/hack-hp-computer.htm
3answers
Forgot password on the acer netbook with windows7
Have you forgot windows 7 password?
Now, we'd recommend you a professional Windows password recovery software- Windows Password Reset as your reference.
As an easy method to reset Windows 7 password , there are only four steps as follow:
Step1: Download Windows Password Reset Deluxe and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows 7 PC by the bootable burned USB in minutes.
Step4: Remove the forgot Windows 7 password on the operation interface and logon PC without password.
10helpful
10answers
I forgot my windows logon password of my laptop. What should i do to get access to my laptop, then?
I think probably the easiest and safest wayfor you is remove your windows password with Windows Password Seeker. I found it at about.com PC support channel last week, and used it to remove the lost passwordwithin 5 minutes. Importantly, the useful tool no need to reinstall Windows. It's worth a try.
1helpful
Forgot password to log into netbook. Don't know how to reset or get in. Can you advise?
if you have windows xp you can try going into safe mode by pressing F8 at start up. once your in windows try logging in to the administrator account (it usually doesn't have a password) then you can change the password on your old account.
If you have windows 7 try following one of these guides
http://forums.oracle.com/forums/thread.jspa?threadID=1100649&tstart=30
http://www.1-script.com/forums/How-to-remove-or-reset-Windows-7-Vista-XP-2000-password-easi-article2702--23.htm
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
