Question about Whirlpool LSQ8243H
Recently our LSQ8243H Washer stopped in the middle of the cycle. The first couple of times it happened all we had to do was open and close the lid and everything was fine. Now it stops and we have to adjust the timer dial. Is it a bad switch? Or is the motor going bad? Or what else could it be that sounds expensive? (lol) Thanks!
Anonymous
    Novelist:
  • 111 Answers
Hi, I'd like to help diagnose your problem but I may need a bit more information. Based on what you stated, I assume you have a top loading WHR washer with an electromechanical timer... the kind that you turn and it clicks. Anyway, you stated that the washer stopped in the middle of the cycle and that simply opening and closing the lid would fix it for a while. I suspect that your lid safety switch may be cracked and isn't being actuated by the plunger on the lid. If this is the case, the washer would function properly until it reached the point in the cycle where it should spin. Then it would stop at that point in the cycle. This makes sense that opening and closing the lid might "fix" it for a while. Also, if the switch got bad enough that opening / closing the lid didn't work anymore, you could rotate the timer dial just past the spin area and the cycle would continue. Have you noticed the clothes are wetter at the end of the cycle?
Anyway, check the lid switch first and then repost if you rule it out.
Good luck.
Posted on Jan 18, 2011
How do I find the lid sensor switch on a Kenmore 500 washing machine
If the washing machine stops in the middle of the cycle then it is very unlikely the lid switch is involved. It could be a number of reasons.
Best to drain the washing machine and repeat the cycle a few times to check if it happens at the same point. Could be a problem with the timer or pressure switch.
You can locate all the parts and their location in this site. I hope I have the correct model for your washing machine.
KENMORE Residential Washer Parts Model 11029522800
Aug 05, 2014 | Kenmore 500 3.5 cu. ft. Top-Load Washing...
Washer fills ok; the wash cycle completes ok, but then it stops; no spin, no rinse cycle. This happens on all wash settings.
A leading problem that will make the washer not drain is a defective lid switch. To check if that is the problem,open the lid and close it slowly,when it is almost closed you should hear a clicking sound,do this a couple times and if you do not hear the click the lid switch is what i would suspect as the problem.
To me a technician with 30 years experience i think the switch is very easy to replace,i believe with some mechinacal ability you too could replace the switch assambly.
If it turns out to be the switch i have attached a youtube video that will show you step by step how to replace it http://youtu.be/MFsvLiuTniU
Good luck,i hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 31, 2011 | Whirlpool Washing Machines
Washer won't spin dry
Safety switch is not opening. When you leave lid up you are negating the safety switch which is activated by the door. Easy fix.
Mar 31, 2017 | Whirlpool LSQ8243H
Follow up
that's odd. the washer would not run in the spin cycle if the lid is lifted but in your case, it would run if you lift the lid.
check the lid also. it could have been damaged and the contacts were able to swap location or change status.
it should be close contacts when the lid is close and open when the lid is open. check the resistance.
tnx 4 using fixya,
drcool
Oct 21, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool washer stops in the middle of the cycle (between Rinse and Spin). What do I do?
sounds like a lid assy issue, can you hear a "clicking" just before the lid is closed, try opening nad closing a few times listening for a distinct "click" if not the machine doesnt think the door is closed and for safety reasons wont spin and drain.if so replace the door lid assy
Mar 16, 2008 | Washing Machines
Washer will not start
It sounds like the lid switch may be bad or have come loose. Open the lid and there should be a thing on the underside that pokes into the washer when you close it. At the place where it pokes into the washer you should see the top of the lid switch and it should be flush with the washer body. Stick a screwdriver into that hole to push down the switch and it should click. Pull the screwdriver out and it should click again. If it does click then close the lid slowly and listen closely near the switch to see if you still hear the clicking.
If you don't hear the clicking, then you will have to change the lid switch (usually costs about 30-50 dollars) or just bypass it. If you do bypass it, be careful. It will still spin even with the lid open and can be dangerous.
Dec 05, 2007 | Roper RAX4232KQ Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
