Question about Reddy R60A Utility Heater
Reddy heater, 50,000btu, won't ignite, no spark at plug, good fuel spray
Posted by sclisle on
D. Floyd Kolb
  • Reddy Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 18, 2011
Heater will not start
Does the blower motor start when you plug it in/turn it on? It may take around 5 seconds if your heater has a HSI(hot surface igniter). If it does you need to check the igniter and the fuel flow. Either way, remove the top of the heater. You will be able to see the fan, igniter, and fuel nozzle. Turn the fan by hand to see if it turns freely. If it does, watch out for the fan and turn the heater on. Look for the igniter to start sparking (spark plug type) or glowing (HSI type). Next, use a flashlight to look for fuel spraying from the nozzle. If fuel isn't spraying, try cleaning the fuel nozzle and check the fuel filter. Watch out for the HSI, if you have one, they are very brittle and easily broken. If you still don't have fuel flow after cleaning the nozzle and the fuel filter, you may have an air pressure problem. Let me know and I will tell you how to check it. Don't forget to rate the answer if it works.
Jan 03, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Want light
first thing you should do is make sure that there is ignition whether by spark plug or hot surface igniter. If you have ignition then make sure that you have fuel spraying from the injector located beside the igniter.If you don't have ignition, chances are you have a bad igniter or spark plug. A failed transformer would be the last thing I'd conclude as bad.
Nov 26, 2010 | Reddy Heater-30-55,000 BTU Variable
Have a rt50 reddy heater and it doesnt ignite the plug has spark and it sprays fuel just doesnt seem to want to start burning
the fuel will not burn in a liquid form, only a vapor, so it must be mixed with the proper amount of air as it leaves the spray nozzle. You may want to take it apart and gently clean out the nozzle with a soft wire brush.
Jan 06, 2010 | Heating & Cooling
My reddy heater R50,(50,000btu)when started will
the unit is working exactly as designed , the system is noticing that the unit has not fired so it shuts down so there is not a lot of unburnt fuel everywhere.
try to find out why the unit is not igniting . is the igniter sparking continually
Nov 12, 2009 | Tools & Hardware - Others
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
No spark to igniter
The ignitor does not spark- it glows.
Dec 22, 2008 | Reddy Heating & Cooling
Reddy heater
getting fuel and spark it HAS to light unless there is water in the fuel. does fuel spray out of the nozzle?
Dec 08, 2007 | Heating & Cooling
Please HELP
www dot desatech dot com is a parts distributor for reddy heat products. on their main page they have a short troubleshooting guide. the motor needs to provide 3.5 psi of air across the fuel nozzle to suck the fuel out of the reservoir. check your ignition source (spark plug, hot surface igniter) if the hot surface igniter is broken get a new one, if the spark plug don't spark, check the gap might be too big. see if the spark plug is grounded. poor grounds will cause intermittent sparking. check the high voltage wire for breaks in the insulation, might be shorting out to ground BEFORE the plug. gap should be 75 thousandths.
Dec 04, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy R60A Utility Heater Logo
1,841 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
