Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Hi, My glass is broken on my Konica Minolta Bizhub 250, could I get a ballpark figure to replace it? Looking forward to hearing from you. Regards, Michelle
taminol
    Sniper:
  • 62 Answers
Hi Michelle,
The Original Glass for a C250 would be around £100. This is my best guesstimate as I don't have the price list to hand. For some reason all copier manufacturers charge a fortune for the glass.
We have a C250 Original Glass which in currently fitted to a C250 in our warehouse. I doubt the machine will ever be repaired, we've taken circuit boads from it to support our field machines.
If you're in the UK and interested, I'm guessing you could have it for around £35 ?
Regards
m-press.biz
Posted on Feb 25, 2011
  • Mary Queen Oct 03, 2012
    Hi. I hope you can help me work out with this one since I'm so devastated by the fact I broke the scanner glass. I'm in UK and can I buy a new glass for the broken scanner? It is HP Photosmart c5280. Thanks. I really need your help ;)
Please reposition orignal bizhub 250
take everything out of the feeder and off the glass open and close the lid and make sure that the sensor that tells the machine the lid has been opened is not stuck if that dosnt work reboot the machine
Jul 04, 2014 | Konica Minolta PRINTING - Bizhub-250...
How to change a Developer for Konica Minolta BizHub 250 Laser Printer, ?
konica minolta c450 how i get test page cyan, magenta, yellow, black separate pages
Jan 07, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 code 0204
The code is an error code, it means your copier bizhub 250 is having some problem in the LCT.large capacity tray the last tray.its not opening or may be malfunctioned.
Oct 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Malfunction c-2552 konica Minolta c252p
Hi, C-2552 on the bizhub C250 means the sensor that measures the Cyan toner level has detected it as abnormally high.
It's likely to be the Cyan Imaging Unit has failed. But try this first..
Remove the Cyan Imaging Unit, give it a gentle tilt (45 degrees or so). Tilt it backwards and forwards a few times, then refit.
Hopefully the code will be gone.
If not, it sounds like the Cyan Imaging Unit is faulty.
Regards
Tam
Apr 15, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
How can i add client pc to scan from konica minolta bizhub 250
HI U must have CD driver to istall twin driver in ur pc and conect usb cable the leed in the right [ + ] will light up if no call ur service
Dec 28, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica bizhub 250
on the left hand side of the platen glass there is a **** glass just clean that with alcohol or wet rag.
HH
Feb 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
111 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
