Alesis TransActive Mobile PA System Speaker System for iPod TRANSACTIVE  Logo
Question about Alesis TransActive Mobile PA System Speaker System for iPod TRANSACTIVE
Battery has died how do I replace it?
Posted by waynepride on
Anonymous
    Sniper:
  • 67 Answers
Quiet easy, but anyhow, now warrenty whatsoever!
you need:
a) one hex screwdirver size 5mm
b) 1 phillips screwdriver size 2
c) 1 replacement battery, maintenance free lead battery block, 123V 7.0AH Type 1270
d) some pieces of 1mm thick foam rubber (4 Strips 150mm, 4 strips 65 mm and 4 strips 95mm, 8-10mm wide would be original, but quiet anything would do it)
e) some glue
f) depending on your expertnes, 20 to 40 minutes time.
... yes thats all.
here we go
DISASSEMBLY
1. lay the unit on to back
2. unscrew the edge plates on the front side (4 pieces, 3 screws each, hex)
3. remove the three edge protectors
4. unscrew the front panel (8 screws, phillips)
5. pull the frontpanel gently up by 2 cm (aprox 1 inch), will be enough
6. lift the grill without bending and remove it
7. unscrew the main speaker (4 screws, phillips)
8. carefully lift up the main speaker
9. look thru the hole, you will see the battery, mounted by 4 screws (phillips again). Unscrew
10. unplig 2 battery leads
11. lift out te battery
ASSEMBLY
1. glue some of the foam rubber arround the new battery, take tie old battery as sample.
2. slide in the battery
3. connect the leads to the battery, the red goese to te red marked pole. Importand
4. Mount the battery holder 4 screws phillips
5. slied in the speaker, mout it wit 4 screws, phillips
6. mount the grill without bending
7. siled the frontpanel back into position and screw ist (8 screws, phillips)
8. bring the edge protectors back into position
9. Mount the edge plates (3 hex screws each)
10. put it back on the weels and load your battery. Testrun.
11. have a beer for me and enyou your music.
Posted on Nov 07, 2011
  • 2 more comments
  • 555R May 30, 2012
    Where can you get this battery. I typed it in search but none are 123 volt only 12 volt
  • Anonymous Apr 17, 2013
    It is supposed to read 12V, not 123V.
  • Ozlek Ozbek
    Ozlek Ozbek Jun 21, 2014
    Thanks !
  • Ozlek Ozbek
    Sry 4 double comment ...
4helpful
2answers
Why does my car's battery keep on continuing to need to be recharged?
The battery needs to be replaced or the alternator is bad. I would try to replace the battery in your car first to see if that fixes the problem. If our car is still not starting up or if the battery keeps on needing to be recharge then the alternator is bad and should be replaced.
Just replaced battery, when put in park it dies?
so when did car last run perfect.
why was battery replaced.
it cranks and runs now.
but never dies driving it?
never dies in neutral?
get car serviced?
read the chapter on idle re-calibration.
here,,
https://suzukipitstopplus.com/Category/3-suzuki-service-manuals.aspx
2answers
Car died replaced battery died again after 2 days. Possible cause?
yes .it also sounds like your alternator has failed.get it checked
Car dies after a short time of running. I took it into an autozone and they tested the battery and the alternator. the said the alternator is fine but the battery needs to be replaced. The car started up...
Sounds like the battery. If its not holding power it will cause the car to die. The alternator will charge the battery and keep power to the vehicle, but the battery is also apart of the process.
Replace the battery and check the battery cables for corrosion. At autozone or wherever you go to get a new battery get some terminal grease/protector for your battery. Its like .99 for a packet and will help keep your connections to the battery from corrosion.
I bought a new Tucson 2006. The battery died in Oct 2009 and I replaced it, died again in May 2010, I replaced it, died again in Oct 2010 and I replaced it. Jan 10, 2010 it has obviously died again. ...
If the battery was made in china, Which walmart likes to buy from, I would go to another store and get one that will work for more than a couple of months. PS Don't get one from autozone either.
3helpful
2answers
Car died at light. battery light on. got a jump start car cranks as long as cables hooked up. take cables off car dies. will not stay started.
Thatttttt's alternatorrrrr.
Your alternator charges your battery. No alternator, no battery charge.
Battery keeps dying?
try to check ignition switch or replace it
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
