Logitech 9311570403 Mouse Logo
Question about Logitech 9311570403 Mouse
How to take out batteries of a logitech mouse?
Posted by crankykitty7 on
Have a Wireless logitech mouse. Replaced battery. Green light comes on, but then goes off. What next?
From Logitech's website, "This is normal behavior of the mouse.
The green battery light of your ]logitech] mouse will come on for a few seconds to indicate the battery condition and then go out. This will occur when you power on your mouse and when you replace the batteries. The battery light goes out after a few seconds to conserve battery power."
2answers
How do you change the battery in the Mouse
model no. all the wireless mouses have battery partition at downside. check it
3helpful
2answers
How to replace the batteries of Cordless logitech mouse of my pc
If it is a LOGITECH V 220 it will be at the bottom of the mouse.
Regards, Kesav.
1helpful
2answers
Need to replace the battery in a Logitech MX Revolution Mouse
Hello. Yes, it is quite simple to remove the battery of a Logitech MX Revolution mouse yet for some reason when going through the Logitech product support website it states that it is not possible. Just remove the 4 teflon pads located on the bottom of the mouse and then remove the four screws located under the pads. Once this is done turn the mouse back upright and remove the top off of the mouse. I would suggest temporarily removing the flex cable that holds the top and bottom of the mouse together. There is a small metal clip that holds the battery in place that must now be removed.
NOW FOR THE VERY IMPORTANT PART. There are two different generations of the Logitech MX Revolution mouse which have different batteries. The first Generation uses the L-LY11 battery and the newer generation of the MX Revolution uses the L-LL11 battery. There is no way to tell which battery your mouse uses without first opening up the mouse. Once opened you can easily tell which battery your mouse uses. Here is a link to a site that shows you an example of the L-LY11 battery: MX Revolution L-LY11 Battery
Here is a link to a site that shows you an example of the L-LL11 battery: L-LL11 Battery for Logitech MX Revolution Mouse
As you can see the L-LY11 battery has wires and a plastic connector and the L-LL11 battery has contacts. You should definitely determine which battery your mouse uses ahead of time to eliminate any frustration caused by ordering the wrong battery ahead of time.
21helpful
3answers
Changing the batteries on a cordless Logitech mouse
hello ,on the bottom of your mouse there is a cover that you remove thats were the 2 aa batteries go. the cover has the wireless info on it you'll see a spot were you can use your finger nail to pop the cover off then after installing your batteries just pop it back on.
4helpful
3answers
Changing batteries on a logitech lx5 mouse
turn off the mouse using the switch on the bottom.
press the battery door release button on the underside of the mouse, towards the back.
that should release the battery door, which is the top part of the mouse, where your palm would rest.
the mouse takes 2 AAA batteries.
3helpful
2answers
EX-110 Logitech cordless optical mouse: does not work
the black section on the top of the mouse with the logitech symbol.
Hold the mouse and firmly but gently slide the black cover away from you , underneath are 2 aaa batteries
2helpful
How do you open Logitech laser cordless mouse to replace batteries?
puhs open the logo area (palm area), toward the backend. it takes 2 aaa battery.
490helpful
17answers
Where's the batteries?
I had a similar problem with my battery going dead in my Logitech mouse. There was a "aa" battery located under the rear top cover. it's the part that has the Logitech logo on it. You simply press the button underneath the mouse @ the back that has a LOCK symbol on it & lift off the cover. Put in a new battery & you should be good to go.
Fred
Top Logitech Computers & Internet Experts
Mehandi Husain ...
Marvin
Marvin
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
