Sony BRAVIA KDL-V40XBR1 Television Logo
Posted on Jan 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I only see screen in black and white. with cable, wii, my laptop is display in color thru a vga cable. what can i do? Marte.
Anonymous
Level 2:
  • Expert 98 Answers
  • Posted on Jan 18, 2011
Anonymous
Expert
Level 2:
Answers
98
Questions
0
Helped
16426
Points
161
Is menu of the TV and / or on-screen display in color or black and white?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2244
Points
what can i do?
Component units not displaying color
I think you need to check the color settings on your new LG TV and ensure all cables are securely connected. If the issue persists, you don't have further options except to contact LG support for assistance.
No display problem, vga's out to external, then after 2nd reboot, internal display works, but with errors
If you have already replaced the screen...
Common problem when replacing equipment on laptops is that the "cable" goes into a flat housing that requires you to lift a little white "gate" then insert the cable and put the "gate" back down. Problems usually occur when snapping the "gate" back down. Pull the cable back out and be sure to lift the gate insert the cable and then put the "gate" back down. Once done give it a light tug and it should hold very firm and not move at all
Rainbow stripes and color changing box
If the screen is damaged, then no there nothing you can do without replacing the screen BUT then is it really damaged? I would try and see if a normal image is displayed on an external display via the laptops VGA port and cable. If good than it is most likely the screen BUT I would look into (By pulling the screen covers off, etc to see if all cables from the System board to the screen is connected properly, if they are and also same image is on the external screen then the graphics chip is the culprit...depends on how hard and at what angle etc did the Laptop hit the foot-board.
My screen keep going white
To me this is a hardware problem.
Let's diagnose, and see Shunka_Reid.
Connect a VGA monitor to the laptop.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
http://support.gateway.com/s/notebook/2009/gateway/nv/NV78/NV78lv.shtml
Number 3 - External VGA display port
General example of VGA connector (port), and VGA cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for the VGA cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
General example of a CRT type of monitor,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY.
Press, and hold the Fn key down, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap on the F4 key once more.
Do you get a good display on the external VGA monitor?
Post back in a Comment.
Also, has the laptop ever been cleaned on the Inside, to your knowledge?
Regards,
joecoolvette
Display divided into 3 parts
LCD screen cracked, and Three even strips going across? Doubtful. Haven't seen it but I always have my mind open.
Three strips that are irregularly shaped? Look like glass that has cracked?
'Jagged edges'?
LCD screen is broken.
Three even strips indicates to me, that there may be a problem with the Video Cable. Then the screen Inverter is next in the diagnoses.
My money is on the Video Cable.
ALL power removed, Anti-Static Precautions FOLLOWED, I would check out the graphics chipset first.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the laptop.
Left rear side. This is an example of a VGA Cable, and VGA connector. (VGA port on a laptop ),
http://en.wikipedia.org/wiki/VGA_connector
(Color of connector does Not matter. It is generally Blue, though)
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
Press, and hold down on the Fn key, and at the same time tap once on the F5 key. (The F5 key is the Display Toggle-Over key)
No display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F5 key.
Is the display on the external VGA monitor, the same as the internal monitor of the laptop?
Problem is the graphics chipset.
Display is fine on the external VGA monitor?
Problem is the Video Cable, screen Inverter, or LCD screen.
Video Cable:
A) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/big/Toshiba-Satellite-A105-14.jpg
Switch Cover removed, Keyboard removed. Shows you where the Video Cable plugs into the motherboard.
B) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/big/Toshiba-Satellite-A105-21.jpg
Palm Rest Cover you can see the white rectangular connector, for the motherboard side of the Video Cable, at the top left.
It's above the black cable, and near the screw hole.
The Video Cable leads from the motherboard, up through the left Hinge, and into the Display Assembly.
From there it connects to the screen Inverter, and back of the LCD screen.
http://www.ebay.com/itm/Toshiba-Satellite-A105-6017B0050801-LCD-Video-Cable-Genuine-OEM-Laptop-TESTED-/290754851160?forcev4exp=true&forceRpt=true
In the photo, (You can hover your mouse cursor on it to enlarge), the right side connector plugs into the back of the LCD screen.
The black connector to the far left connects to the motherboard.
The small white connector at the top with the Red, Green, Black, etc wires, connects to the screen Inverter.
(The small Black cable, that comes out from the black motherboard connector, is a Ground wire )
Due to the close proximity of the Video Cable to the left Hinge, it can be pulled on from just normal opening, and closing of the laptop over time.
This means the Video Cable connection on the motherboard side could be loose, or the LCD screen side, or both.
The diagnoses is to PHYSICALLY check BOTH connections. A loose connection at the motherboard, or at the back of the LCD screen could be so small in distance, that you will not see it with the human eye.
Could also result in damage to the Video Cable.
View the Video Cable with the Switch Cover removed, and see if there are any obvious signs of damage to the sheath of the cable.
If there is there could be damage to the tiny wires inside the Video Cable. (Stretched/Broken)
Use a multimeter set to OHMs, to check all wires inside the Video Cable for continuity, or have a 'Mom and Pop' computer store check it for a few bucks, or replace the Video Cable.
Video cable connections are tight? Video cable continuity check checks out OK?
Screen Inverter.
The test for a screen Inverter is to use a sensitive multimeter.
Read fairly expensive.
http://www.fonerbooks.com/test.htm
Not having access to a sensitive multimeter that you can use, means just replacing the screen Inverter. Seems like 'part changing', and it is, but you have to work with what you've got.
http://www.sparepartswarehouse.com/Toshiba,Satellite,A105,Laptop,Inverters.aspx
Find THE model number for your laptop, and the correct screen Inverter. A screen Inverter, and an LCD screen are a MATCHED unit.
Screen Inverter is checked out to be OK, or replaced, and symptoms are still the same, the problem is the LCD screen.
Remember, the first part of the diagnoses was to see if the divided parts were EVEN going across, or jagged and irregularly shaped.
Jagged in shape, and not even strips going across, means cracks in the LCD screen.
Replace.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
[ Main article for A and B links above;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm ]
For additional questions please post in a Comment
Regards,
joecoolvette
How to remove white and black leakage screen
Your lcd screen has gone bad and needs to be replaced. To isolate that it's the screen or the video card borrow a monitor from a relative, neighbor, friend or co-worker and plug it into the laptop. If the borrowed screen displays fine without any problems then your original screen is bad. If the borrowed screen shows the white area with black leakage ink as your old monitor then the video card in the computer is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
I have an HP dv9700 laptop. Upon a complete restart, before my desktop comes up, I have complete neon green static type lines. It disappears after desktop appears, but when online, any black areas have...
change the vga resolusion to 600*800 or another from display setting .if you feel any change to screen color , the graphic chipset on mainboard has damaged,
if not the LCD flat cable or LCD has problem
2answers
Color of lcd monitor for noebook is inverted
reboot safe mode and see if all looks ok, then make changes ot display as you prefer it to be. check vga cable check windows desktop theme
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
