Question about Reddy Heater-30-55,000 BTU Variable
My RM60 Reddy Heater has a strong kerosene odor when utilizing. How do I minimize this?
Posted by eight2score on
D. Floyd Kolb
  • Reddy Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 17, 2011
Need electroed part #0344-3 ready heater rem60 or r60 or rm60 60;000 btu
Any parts you need for any Dayton products can be purchased from Grainger...
www.grainger.com
heatman101
Jan 16, 2011 | Dayton E48 Oil Filled Utility Heater
70,000 btu reddy heater, starts right up but smells bad.Instaled new filters , fuel and igniter low hours 100 or so. disassembled tip everything looked perfect.nosecone turns orange from bottom up and...
I hope you are burning K1 kerosene as opposed to off road diesel. Diesel stinks no matter what you do to the heater. A couple things that have happened to me are, fuel selection K1 is it, when storing for the end of the season old fuel can cause water from condensation to build in the tank. When water is in the tank you get ignition and it burns just not hot enough to burn the fuel completely, this causes the heavy odor. Old fuel will do the same it is as if the fuel thickens to an oily state and becomes heavier. It just does not burn hot enough to get rid of the odor. You can try increasing pump pressure this changes air fuel mixture and you may get rid of the odor somewhat.
Dec 23, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
My reddy heater was running and ran out of fuel at which time it gave off a foul exhaust. Was this exhaust carbon monxide or just the sulfer smell associated with kerosene?
probably both and unburnt fuel also. when the unit ran out it still pumped a small quantity of fuel into the hot burner chamber where it turned to smoke and was expelled. carbon monoxide itself is odorless and what is normally referred to as c. o. odor are unburnt fuel products, some of which smell pretty strange.
Jan 14, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater will not stay on rm60 reddy heater
When you say the heater is coming on does it actually ignite or is the motor just running until the safety circuit kicks it off? The air pump on you heater should blow at 3.5 to 4 psi which runs up to the nozzle which is a venturi which sucks the fuel out of the tank. The motor will generally run for 20 to 30 seconds trying to ignite. If the flame sensor does not sufficient flame during the time it shuts the motor off. Check these items and let me know what you find.
Jan 07, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater 60k kerosene suddenly smells
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Mar 09, 2009 | Reddy R60A Utility Heater
Reddy Heater-30-55,000 BTU Variable Logo
359 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
