Question about Samsung Refrigerators
Our Samsung SR-V43H refrigerator light switch suddenly sparked and now the light does no work. The light switch is visibly burnt. How can i fix it?
4 Related Answers
Anonymous
SOURCE: Samsung Refrigator
how do i fill up the water and ice maker
Posted on May 09, 2008
Anonymous
SOURCE: samsung refrigerator sr-l628ev ,refrigerator not
I don't have a solution, but I have the same problem. Or rather I did until today when the freezer started defrosting itself too.
It sounds very similar to the RS21 problem that is on the watchdog website, but as my fridge/freezer is 8 years old I don't think they are going to give two hoots about repairing it foc.
Posted on Aug 24, 2008
Anonymous
SOURCE: Samsung SR-L39 fridge freezer switching off
tarsia upatvane
Posted on Aug 30, 2008
caroldon
  • 17130 Answers
SOURCE: for Samsung Refrigerator SR-L629EV my freezer
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Posted on Jul 19, 2011
Samsung SR-161KTC fridge light wont work not bulb
lift the tab in center of socket , hold light switch in while doing this. or check the light switch itself.
Nov 09, 2013 | Refrigerators
How do you reset the display temperature
follow this steps and fix it. God bless you
    • 1
      Press the "Fridge" button on the refrigerator's front panel.
    • 2
      Press the "Fridge" button until there are more lights visible on the panel next to "Fridge" to set cooler temperatures.
    • 3
      Press the "Fridge" button until there are fewer lights visible on the panel next to "Fridge" to set warmer temperatures.
Read more: http://www.ehow.com/how_7696789_reset-temperature-samsung-refrigerator.html#ixzz2Ze3Som8U
Jul 21, 2013 | Samsung RS2630SH Side by Side Refrigerator
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
I have a Samsung Cooltech Plus fridge that seems not be able regulate the temperature correctly. At times the temparature is 22 celcius and food gets spoilt, I tried switching it off and on again but that...
Keep your hand on condenser coil if it's visible or left and or right side body of the fridge. If you feel hot the gas is o.k. Otherwise no gas or chock. You have to repair and refill the gas.
Dec 08, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung Cooltech fridge - type SR-52NXA - when working very strange noise coming from the fridge. The "pole" from air mixing flow system is not turning/spinning
Yes, I had this problem. $85 visit from a very condescending repair man located a piece of old hard cheese that had become wedged in and stopped the thing from turning - the noise had been terrible. Fixed in 2 minutes - embarrassment lasted much longer.
Jun 05, 2009 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung Refrigerator SR-608EV with water dispenser
There is another sensor in the door that senses how far open the door is. look for this and see if its disconnected or broke
Jan 26, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
replace the thermostat of the freezer
Sep 16, 2007 | Refrigerators
Refrigerators Logo
190 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
