If your copier has a hole punch unit you should be able to go to output and select hole punch.
If you're trying to print with hole punch from your computer and you dont have the option, you need to configure your print driver. Check out the link below for instructions.
Which model is it? The MX-350N is black and white, the MX-3501N is a color model. I'll assume it's the MX-3501N.
Either it's defaulted to print B&W in which case you just go to your printing preferences of the print driver in the printers menu in the control panel, and uncheck the "black and white print" box, or you have account/user codes that you need to enter in your print driver in order for it to print color. Instructions for adding a user code to the printer driver are found here.
Are you using the correct print driver? Many times, if the print driver is for a similar product, it may not have that option. It would be a good idea to see if you have the specific driver especially the PCL6 version.
Most envelopes should work as long as you have:
1) fed them from the right side manual feed tray face down with the short side to the copier.
2) selected ENVELOPE as your paper type to run slower and lower your fuser heat.
The copier is designed for envelopes that have the flap down and the regular wettable adhesive. If you have gummed adhesive with a waxy peel strip that you remove before closing, the copier may not be designed to handle this. It may also help to put the front and rear pressure tabs on the fuser in the UP position.
Install the print driver, from the app you are printing from select your copier and then Properties, under the Paper tab you can select your paper type and tray. Only use the right side manual feed tray for envelopes. You may also need to set paper type ENVELOPE COM-10 in the copier. Extend the manual feed tray fully and set the guides or the copier will not read the correct size.
If this is when you select this machine to print to, it may be because the print driver is not configured properly. Go to main driver under start, control panel, printer, right click on printer, select configuration, then auto configuration and select everything with a finger pointing to it. Then try again.
