Question about Navman Mio M400 Car GPS Receiver
When switched on my navman m420 screen is blank even after charging
Posted by elaineandbar on
Laurent M
  • 57 Answers
Try this: 1. Connect your device to the computer 2. Make a backup of your addresses and favorites if you wish 3. In File Explorer, right click on the device (removable drive) >> Format 4. Start the Desktop 5. Go to My Mio >> Reinstall the software 6. Go to My Mio >> Recover Keys 7. You can now reinstall the maps from the Maps tab. If you downloaded a map update, make sure to use the downloaded file. 8. Go to My Mio / Voice Transfer and re-install the voice files
Posted on Feb 25, 2011
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
When i turn my satnav on open page comes on and then it showes a picture of satnav charging from a laptop and will not go to anything else can u help me please thanks graham
Hi Graham,I had exactly the same problem with my Nav Man S50. After the icon of the lap top my screen went blank. I updated it via the soft ware provided but no updates were available. In fact the problem turned out to be the on/off switch. Although it was glowing red it was not charging. I simply placed a pen into the switch and it worked.
Hope this will help.
Maureen
Sep 04, 2011 | Navman S50 Portable GPS Automobile...
How do i romove the demo from my mio m420 it keeps coming on mid way through another route
On the main menu, go to My Mio, then scroll all the way to the bottom and disable shop demo
Dec 31, 2010 | Navman Mio M400 Car GPS Receiver
Navman m420
This Sat Nav system is a total let down! I could not use it to navigate in Bournemouth city centre, it kept on telling me to turn in to one way streets going opposite traffic and could not even take me to Luton airport (so basic!) neither LU2 9LY nor LU2 9QT postcodes were recognised by system giving error: NO MATCHING POSTCODES
Even after full software update the device was clueless what to do with many basic post codes. I may as well bin this and buy a well-known brand instead!!
Aug 10, 2010 | Navman Mio M400 Car GPS Receiver
When I switch on all I get is a picture of a battery with arrows going left to right.then a blank screen
When i turn on my Garmin the picture on the screen is very light i cannot see the screen what should i do?
Aug 14, 2009 | Navman GPS
No power to my ICN 520
Have you tried the reset hole? make sure there is nothing stuck in there that could be pressing on the button. When you press and hold the reset button the screen stays blank.
If you press the reset button does the unit turn on? Mine turns on when I press the reset button even after I turn the battery off then back on.
Hope this suggestion might help you restore functionality.
Jun 08, 2008 | Navman iCN 520 GPS Receiver
Battery Charging Navman S90i
The problem is that most of the chargers have the output of 5V/0.5A. The charger for NAVMAN (C30 in my case) has 5V/1A. And that is causing the trouble. The GPS is undercharged and is switching off itself. Buy one which specify the output power: 5V/1A. Hope I solved your problem
Feb 04, 2008 | Navman F20 GPS Receiver
Navman f10
i was in car,using navmanf10, went blank and a comput screen connect to unit appeared, cannot do anything with it
[email protected]
Dec 28, 2007 | Navman Tracker 5500i GPS Receiver
Navman Mio  M400 Car GPS Receiver Logo
802 people viewed this question
Top Navman GPS Experts
Ekse
Marvin
Marvin
Are you a Navman GPS Expert? Answer questions, earn points and help others
