Question about Radio Communications
Backlighting not working on a dx 33 hml - Radio Communications
Posted by mabailey_1 on
wcrave
    New Friend:
    Problem Solver:
  • 19 Answers
The Galaxy DX33HML does not have backlighting. If you mean you have Nitro knobs that don't work, you should take it back to whoever installed them. There is no way to tell how they were wired.
....Don at NTCB, Inc.
Posted on Jun 29, 2011
I have a galaxy dx 33 hml it was doing fine till it fell off dash , now when I key up its really loud through my talk back, and it squeels . Does anybody know what could have happened?
you may have cracked the pcb board and its shorting out the audio and thus making it squeal. Best to take it to a tech and let them tell you whats wrong .
Oct 18, 2015 | Radio Communications
How do I set my swr on my galaxy dx 33 hml CB radio with a astatic swr meter and a top loaded tunable fire stick antenna
Watch the meter as you adjust the antenna. Try to get an SWR of 1:1, or as close to it as you can get.
Jul 30, 2014 | Radio Communications
33 dx hml no audio on receve
problem lies within the radio and if you have to ask then you are not certified to do the work.Find a tech to do it.He has all the equipment and the know how.
Feb 07, 2014 | Radio Communications
How much is a dx77 hml used worth
how much do you think its worth? If you feel its worth 100.00 than you buy it.If you are buying it to resell it then you gotta pay less to make any thing from it. Check out what they cost new then determine what you want to pay from that figure.
Jan 14, 2012 | Galaxy Radios DX 77HML Base CB Radio
Galaxy 33 hml
This is not a simple answer not knowing if it ever worked or not. I have a rfx75 installed on a DX 88 and it preforms flawlessly. If I were you I would find a reputable CB Shop and ask for their help.
Jul 03, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
I need a users manual forthe Galaxy 33HML CB radio.
Enter Galaxy DX33 HML manual (or user's manual) in your search bar, you should be able to pull up a pdf file on it. This is how I got my manual for my Galaxy 33DX HML radio.
Jun 27, 2009 | Galaxy Radios DX-33HML 40-Channels Base CB...
North Star DX 330 HML has no receive
Radio dude, we'll try to help with the problem your having with your Northstar base. I assume you have checked all the controls to make sure they are functioning correctly? ok, based on what I'm reading for the problem, I'd say your looking at a bad solder joint on the main circuit board, or a close powerful station might have keyed up and blowed the front end out of your receive. There are 1 or 2 fet transistors in the RX chain and with the age of the radio, one of those going bad on it's own is a possibility. Sounds like it needs some hands on troubleshooting, are you electronically able to work on it?? Hope this helps in your search and let us know,, Mechanic
Feb 22, 2008 | Galaxy Radios DX-33HML 40-Channels Base CB...
Galaxy dx 77 hml
I'll be back in my shop on the 24th. I'll open a 959 and see if it has the same configuration and maybe it will help. My nuber is 307-266-4675. I hope it helps.
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Galaxy Radios DX- 88HL Base CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
