I have exactely the same problem with my CM67NG. Did you find a solution to fix it? The radio link synchronization is OK and all the parameters (OP, Ot, Cl, At, rP, HC, PE, Cr, St, UL, LL, tO, Pb, LC and FS) have been checked. I also tried to go back to the factory settings without any success...
Welcome to fixya Hello I have a solution for this Press Ok, Accept or replay so we may get started Your pre-solution is coming up shortly PLEASE
REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL My name is Bruce
Hi Bruce,
I'm sorry for my late reply to your post... I would still very much appreciate your advise.
Thank you. Regards,
Gus
Hello Bruce, i have the same problem. I will be very glad to know the answer ! Thanks !
Hello Bruce, Hope you still read this comment. We have the same id problem with our Honeywell thermostat, can you give us advice? Please contact me by e-mail our reply: [email protected] (Netherlands). Thanks in advance! Ron
Hello Bruce
I have the same problem can you help please? You can call me on 0789 990 7948 or email me [email protected]
So have I ,. Solution ? [email protected]
Welcome to Fixya,
The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
I hope this will help you.
Thank you for usinf Fixya.
I have exactly the same problem.
Do you already know how to solve this?
Best regards,
Frederic
I have the same problem. Please, can you give me any advice?
