First off how old is this stove,there's alot of parts discontinued for this,like the clock assy. and if the oven isn't working this could be your problem.get someone that knows how to use a meter,let them check to see if you have 240 volts going to the oven,if so check to see if power is coming out of board if not the board is no longer available.did anything happen while you were using it or a power failure and has the clock ever gone blank on you or anything like that,if so that also is a bad clock assy. or computer board.
SOURCE: Super Capacity 465 Gas Range
my gas stove top burner will not ingnite when I turn on the gas.
I have gas supply to the house, the gas stove top makes the tick tick noise when you
turn one of the burners on, but no flame, even if you try using a match.
What all can I checK?
SOURCE: 2 of 4 burners ignite, all tick?
The two front burners are used most often. On the side of the burners are tiny holes that become plugged and keep the burner from lighting. If all the burners are the same size try swapping the heads around. If they are not all the same size be sure they are in the correct position and fully seated on the top. Sometimes the heads have to be replaced when cleaning no longer works.
SOURCE: can't get door back on- 465 super capacity
I use 2 screwdriver handles between the hinges and the cabinet to hold them out. Then slide the door on part way and pull out the screwdrivers. Voila! Hope this helps!
SOURCE: Whirlpool Super Capacity 465 Electric. Left Front
there are 3 screws under the front of the top with the oven door open actually there are 6 screws but only 3 you need to remove to raise the glass top up!! to service the burners
Hi madluscious1, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the whole model number?
