Mitsubishi WD-57733 57" HDTV Logo
A
Anonymous Posted on Jan 17, 2011
When the TV first went out there was no picture or sound so I replaced the bulb and had sound and pic for about 6 hrs total between 2 days of watching the TV. So I sent that bulb back and received an upgraded bulb. Now after putting in that new bulb I hear a clicking noise(like a cricket) then static noise-no picture-light blinks and then turns itself off. Any ideas???
Chi Chu
Level 3:
  • Mitsubishi Master 8,457 Answers
  • Posted on Jan 17, 2011
Chi Chu
Mitsubishi Master
Level 3:
Answers
8457
Questions
0
Helped
2822699
Points
26282
This tv have a board call the ballast board to help the projection lamp to ignite.U hear clicking noises mean the ballast board is dead,not doing it job igniting the projection lamp.
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
2helpful
2answers
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
My Toshiba 32AV500U - the picture went blank.
This problem usually happens when the lamp runs out, verify how old is your TV, lamps have a life spend of aprox. 3 years, most likely you would have to replace the bulb so your TV can start running again!!
1helpful
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
2answers
Intermittant shut down with blinking green light on Sony TV 55"
Hi,Make sure you get the Original Philips lamps since they last 6000-8000 hrs 2-4 yrs,way better then Osram which last 4000-5000 hrs 1 - 1/2 yrs.
LAMP JUST WENT OUT
I have a 57" DLP and have replaced the bulb 3 times in 2&1/2 years. I'm not possitive but I think I have 6-800 hrs on it total. Mitsubishi claims it a part they expect to go out, but the told me they typically last about ten yrs. If you have proof of purchase they will send you a new one for free, otherwise it'll cost you about $150 on ebay.
No pic No sound
your bulb is connected to all the audio
the bulb blew out and you need to have it replace local cuircut city has a repair man on call for this
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
