Question about Robitussin Cool Moisture 1 Gal. Humidifier
I have lost the instructions to my robitussin DM-832 humidifer. could you send? [email protected]
Posted by spotter664 on
Can you give Motrin and robitussin together?
Your best bet is to ask your physician or pharmacist. If Robitussin contains the same active ingredient as Motrin, the answer is most likely NO, because it will be too easy to overdose. Otherwise, I don't know if there will be any interaction between the two drugs. Sometimes a combination will cause problems for certain individuals but not others. Again, ask a professional.
Dec 18, 2014 | Robitussin Humidifiers
How do i use this humidifer i lost the instructions please help
go to http://download.gracobaby.com/ProductInstructionManuals/ISPD022AB.pd then you have your own
Mar 05, 2011 | Graco 15 15 Gallon Humidifier
Model RCM-832. On/off switch works, blows air but no moisture seems to come out. I left it on for at least one day and the water level in the tank remained the same.
First check humid-stat setting make sure that the room is not above setting. Second check that float(water level) switch is being made. Hope that helps
Feb 08, 2011 | Robitussin Cool Moisture 1 Gal. Humidifier
Continous water flow on a 1042lh humidifer
theholts220 - Sounds like they needed to install a bit larger transformer . You can also buy a A 50 Sensing relay that attaches to the wires for your motor and when you turn on the furnace it will allow the power to go to the humidistat. Very strange though they do not use a lot of power. Check and make sure the wires are not pinched or touching metal somewhere.
TLuzzo - The humidistat seems to be working when you turn it down. The wires for the solenoid should be hooked up to your furnace circuit board. The instruction manual will tell you where. If you dont have a spot on your circut board the A 50 sensing reley is they way to go. They are inexpensive
Jan 24, 2009 | General Filters 1042-LH Humidifier
Humidifer white dust no filter
Try usubg distilled water (or water with less minerals in it).
Feb 07, 2008 | Vicks Ultrasonic V5100 Humidifier
Robitussin Cool Moisture 1 Gal. Humidifier Logo
Top Robitussin Humidifiers Experts
Tom Chichester
ray gallant
ENFORCER
Are you a Robitussin Humidifier Expert? Answer questions, earn points and help others
