Overflow problem possible causes: 1) water is over the "10" marker, 2) no filter in basket 3) too much (or too fine) of coffee in the basket -- does not drain. Also make sure the "spring" on the bottom of the basket is not stuck (the one that lets you remove coffee carafe without dripping coffee.
Well, I've been using this coffee maker for almost four years, and the issue of coffee overflowing gets worse. Each time, I check the spring and clean out the filter and grinder. On mine, the spring seems to be the issue, but it's almost impossible to fix at this point. This is the worst coffee maker I've had.
