Question about Sony Playstation 3 (PS3) Console
Ps3 wont turns on briefly then the light turn yellow then flashes red and turns off is there a quick fix for this problem?
Posted by jack_bishop on
Anonymous
  • 21 Answers
Bad news unfortunately no easy fix. The on real fix is to reballing the main microprocessor using a IR rework station. Only a few electronic repair agents have this equipment and a select few are willing to perform this repair. The problem you have is also known as YROD (Yellow Ring of Death).
Posted on Jan 17, 2011
When i switch it on it goes green for a second, briefly flashes yellow and then flashes red until i press it again and it goes solid red
Hello there schofield
If you have the brief flashing yellow light, then its followed by a red blinking light then you have the yellow light of death AKA the YLOD.
The lights are a warning sign to let you know something is wrong. I can give you the quick explanation, There are 2 chips on the motherboard inside the PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the solder heats up and when you finish playing it cools down, over time this will cause the soldering to crack and the chips to lose connection with the motherboard and you get the YLOD.
WHERE TO GO FROM HERE
Option 1 - Call Sony
In warranty the Price is Free, out of warranty the Price is $150, the whole process is 4-6 weeks
You can call Sony and they will collect the PS3, repair/replace, and deliver the PS3 back to you
Option 2 - Fix it your Self
You can use a PS3 fix manual to get this fixed easily and at home using household tools you probably already own.
Click here to know more on PS3 Fix Manuals which has helped so many people like you.
Good luck
Best regards
Peter
Jul 31, 2011 | Sony Playstation 3 (PS3) Console
My ps3 light turned yellow then it turned off,now when i try to turn it on,it wont turn it does the same thing
Hello there moses
Good luck
Best regards
Peter
Jul 28, 2011 | Sony Playstation 3 (PS3) Console
Playstion wont turn on keeps beeping and shutting down flashing red light
you have the yellow light of death :( sorry to hear the bad news my man the ...yellow..... im reffering to is the quick yellow after the green before you get red its very quick and very paining aswell as it means you need a service call or someone qualified to fix it ok luckily people on kijiji in my area fixed mine for 40$ and it works great now so i suggest starting there ok :) hope this helps u ok
Jun 02, 2011 | Sony Playstation 3 (PS3) Console
Hi, my ps3 wont turn on, but the red light flashes green, yellow and then red again, Whats wrong with my ps3? My ps3 will be plugged in, turned on at the back, so the red light in the front is on. When...
i had the same problem. cost $70.00 to get it fixed. it is just temperary. 4 month warranty,it did the same thing again. an ower of a computer shop said they use to fix them, but it was not worth it. they all last that long and then would have to be replaced.after being fixed the first time.
Mar 30, 2011 | Computers & Internet
Briefly turns on beeps flashes yellow and turns off
Welcome to Fixya
YLOD or yellow light of death (indicated by the flashing yellow light). When you are Experiencing Problems with the PS3 like this you mainly have 2 options to take.
Option 1
Send The PS3 to Sony
Almost all problems with the PS3 Sony can fix easily if not they will send you a refurbished model.
Price:
If your in warranty they will not charge you for this repair/replace.
If your out of warranty the Charge will be $150
Waiting Time:
4-6 weeks
Sony Contacts right here
Option 2
The PS3 Repair guide
When your suffering problems with the PS3 its often easy enough to fix it at home with a good ps3 repair guide. There famous for fixing major problems like:
The YLOD - Yellow light of death/ Red light error
The Disk Read error
The Hard disk Corruption error
The Red Screen of death - Serious error
PS3 Freeze up Error
PS3 No Signal Error - no display
FIX All error messages
But not everyone knows they can fix simple settings problems like all error messages and the no display error, av and hdmi screen problems and more.
Price: averages between $40 - $60
Wait time: instant download and repair within 2 hours
I really hope I provided you information to fix your problems with the PS3 and get back to gaming soon as possible.
Thanks!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont turn on
PS3 red indicator light flashes with yellow means hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only such yellow light flashing problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Jul 19, 2010 | Sony Playstation 3 (PS3) Console
MY PS3 wont start up, everytime i press the start up button it turns green for a second and then quickly turns yellow and shuts off
That yellow light is what us gamers refer to as YLOD.. Its the Yellow Light Of Death. Your system will have to be serviced by Sony. If your system is under warranty still it wont cost you anything but if its not, Sony charges 150.00 dollars to fix/replace it. They will send you a box in the mail to send it to them. Turnovers usually 2-3 weeks. My condolences to you and your PS3. Best of luck to you.
Oct 24, 2009 | Sony Playstation 3 (PS3) Console
From standby PS3 wont turn on.
that sounds like your main power supply unit
May 28, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
