Question about Samsung PS50Q91HD 50 in. HD-Ready Plasma TV
What settings do I use to obtain the best possible picture from my Samsung Plasma TV 50"/127cm HD PS50Q91HD 50 in? The ones that I am using don't seem to be giving me as high definition a picture as other plasmas that I have seen? Thanks Dave
Posted by coastaldemol on
Anonymous
  • 21 Answers
Use you HDMI Input, depending the source your using has HDMI output resolution is 1080p or 1080i
Posted on Jan 17, 2011
No picture on Samsung HP-R5052
Just a couple of things to try:
You say you tried another cable box and a roku. Are you using the same cables? Are you using hdmi, component or coax cables? Could be a bad wire. True high def tv 1080 requires an hdmi cable for the best picture. The next best choice is the component cable. This is a triple cable with red, green, & blue and provides 720 resolution. The least quality is the coax wire which will only provide low def standard quality picture. Sometimes people hook up 1, 2, or all 3 of these choices not knowing what it all means. If thats the case with your tv it may just be a matter of selecting the correct input on your tv with your remote. On your samsung remote there should be a button for input. Try pushing that button and make sure it's set to hdmi or component, whichever your using. If none of this, is it possible the plasma tv itself is defective?
Apr 08, 2014 | Samsung HP-R5052 50 in. Plasma HDTV
What is the perfect setting for my samsung series4 plasma tv so i can enjoy the perfect picture on this tv
Best way to set is watch a program with lots of human faces; then adjust the color and contrast for most human like picture and the rest will become more perfect. There is usually no factory adjustment listed in the manual. But you can download the manual online and check it if you wanted to do so.
Feb 05, 2018 | Samsung PS50P7H 50 in. HD-Ready Plasma TV
Hi, I used to be a TV Technician and I am considering buy a Samsung PS50Q91HD 50"Plasma TV with an alleged Power supply problem. Just wondering how difficult that would be to replace and how...
I would not advise you to buy a non working TV specially when Plasma is moving out and the new technologies with 3D- LED is around bringing the prices down.
Also the cost is not the factor but if there is fault on the mother board then you are stuck and would have wasted money on a junk. So please do not commit UNLESS you can source a power supply unit - SMPS unit - and make sure that it is the ONLY issue. Let the TV work and then after seeing a good picture you can take tbhe risk... but the cost is also important and must be checked out.
Aug 30, 2011 | Samsung PS50Q91HD 50 in. HD-Ready Plasma...
Hello, we we have a 50 inch Samsung Plasma TV, from Bestbuy, went to bed and it was working fine, woke up and now we have audio, but NOTHING on screen, completely, black...also tried DVD and same thing,...
Tries tv unplung,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.Tv now 50/50 the tv might work as normal again.If the tv dosen't.Tv have a dead 1 or 2 backlight buffers boards have to be replacing.These 2 long backlight buffers boards only job are to provided a tv plasma screen panel for a backlight to see the picture.Tv now the plasma screen panel have no backlight that why ur tv have only audio sound and no picture.No experience in tv repair and never done any electronic board parts replacement before.Best just call many tv shops and explain the tv situation it in and get the best quote prices for parts and labors.Best prices parts and labors should be around $400 is fair more than that as i said shops around for more tv repair shops.
Aug 19, 2011 | Samsung HP-R5052 50 in. Plasma HDTV
I have a new insignia 55 1080p led tv . What is the best picture settings?
Personaly I think these settings are the best for the insignia
Contrast: 38
Brightness: 50
Sharpness: -50
Color: 45
Tint: G3
Backlight: 3
Jul 25, 2011 | Insignia NS-P502Q-10A 50 in. HD-Ready...
Just bought the Samsung 550 Plasma Hd Tv can you tell me if we just use a regular cable from the wall to the Tv will the picture quality be sort of off.. WE have an HM MI cable from the cable box to the TV...
unfortunately cable does not give you the best quality picture and "fuzziness ' is the reduced resolution being displayed on the tv.
the easy way to check the picture quality is to get a decent hd antenna and scan using it for free hdtv signals, if these are also fuzzy, on all channels then the tv has a problem but if it is only on a few lower resolution channels then its just the way it is until everyone is hd 720 or better.
Jan 31, 2010 | Samsung 50 in. Plasma TV
Picture quality for gaming
Match the PS3's output resolution to your TVs (in this case 720p).
Don't sit too close, otherwise you'll start to see individual pixels.
Make sure the HDMI cable is good quality.
As for picture settings, they will very so much according to the viewing conditions that i cannot give you settings that are gauranteed to work for you. But sharpness should always be 0 when dealing with HD content.
If you want to really get the best picture from your TV, try using a THX disc to calibrate it. Luckily these are normally included on Disney PIXAR DVDs, so go find yourself a copy of CARS or something. Follow the instructions of the THX setup, and you should have youself a sweet looking picture in no time.
Hope this Helps.
Apr 28, 2009 | Samsung PS50A457 50 in. Plasma TV
Fill the screen
Depending on what source you are using, this is possible. Most digital sources are set and cant be changed by the tv leaving black bars. Though video, svideo and component should allow multiple masking and cropping modes to strech the picture.
Nov 01, 2007 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Samsung PS50Q91HD 50 in. HD-Ready Plasma TV Logo
248 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
