Question about Kodak ESP 5 Printer
Kodak esp 5210 code error 3533 paper jam no paper in it
Posted by dsparnon on
imaginthaton
    New Friend:
Leave the rear cover off, then spam the OK button if the error message remains on. I did that maybe 10 times in rapid succession, then hear a very distinctive CLICK in the back of the printer. I replaced the cover, the hit OK, the printer cycled through startup, and now it's operating normally.
Posted on Jan 12, 2013
5 Related Answers
Anonymous
SOURCE: Paper jam in a Kodak ESP- Printer. please note spam number below
Right here we go. As already said above somewhere, slide the ink cartridges to the right, with a torch look into the left hand side where they had been sat. If you can see a pad there which when pushed it springs up and down ( and you get a black inky finger) push a plastic lug type lever at the back of this pad towards the back of the printer and the pad will slide backwards to reveal two squeegee rubbers stuck up. that is now the cleaning head unjammed. shut the top press ok and away you go, Simples.
Posted on May 27, 2010
Anonymous
  • 8 Answers
SOURCE: kodak esp 7 has a
If you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
Posted on Mar 05, 2010
Anonymous
SOURCE: ESP 7 paper jam error
I had the same problem, but after pressing the OK button when the paper jam came up again I pressed the CANCEL button and was able to print my document. See if that works for you too.
Posted on Apr 12, 2009
Anonymous
  • 6 Answers
SOURCE: Kodak ESP-3 Printer Red Flashing Light
Couple of things.
1. Look inside the printer by the print head. On one side you should see a felt pad of some sort. Make sure this has not come loose. If it has, it can block the path of the print head and will read paper jam. I have seen this mostly with the ESP 5, but I suppose the same could happen with the 3.
2. This way is kind of long but will clear a lot of problems. Open the top of the printer and remove both cartridges and the print head. Unplug the power supply and close the printer. Wait about 30 seconds. Now plug the power back in and wait until the printer stops moving inside. Open the printer and instal just the print head. Unplug and wait 30 seconds. Repeat this procedure with installing the black, then the color. Make sure you unplug for 30 seconds and wait for the internal parts to stop moving between each step. his should fix everything. It has worked for me several times. These really are a decent printer, just a little glitchy sometimes.
3. Make sure a paper has not gotten wadded up and is hidden inside to the left or right of the print head. I have seen this twice in the ESP 3.
Hope this helps.
Posted on Apr 18, 2009
Anonymous
  • 8 Answers
SOURCE: i have Kodak esp 5 all in one- says I have paper
f you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below. Works for esp 7.
backward.
My kodak printer esp 3.2 is giving me an error code 3533 paper jam but there is no paper jammed and when i put new paper in it, it still wont print and keeps giving me the same error code 3533
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Paper jam code 3533
In removing the jam you have pulled aswitch in side loose . Usually a plastic black switch that will trigger this . It is inside and will need to be reset inplace.
1helpful
Paper jam error
remove the tonner and check may be a piece of paper be hidden in the machine
Koday esp c310 error 3533
I have code 3533 code but paper is not jam
29helpful
3answers
Get a paper jam error code 3533 but nothing in the copier. caution spam number below
I hit on mine several times and slammed it on the table a few more times and it cleared the jam. Seriously.
1helpful
Esp 5250 error code 3528
Hello Shaheen,
Try this:
To resolve the error:
  1. Press the On/Off button on the printer control panel to turn off your printer.
  2. Wait 30 seconds.
  3. Press the On/Off button to turn on your printer.
If the error continues, double-check that all paper and foreign objects are removed from inside your printer.
NOTE: Even if you do not physically see a paper jam, you will need to follow the paper jam link to solve the error.
Paper Jam Error
2answers
My kodak esp5210 printer is showing paper jam remove rear access cover. clear all papper. attach cover. press ok to continue. (code 3533). ive followed the instructions but nothing changes. there never...
I've got exactly the same situation/circumstances and error code, the thing different is that my code changes between 3533 and 3528? sorry I;m no help right now but I'll be back if I solve it. Martin. ([email protected])
I just installed a new Kodak ESP 5210 printer. It will not print out documents, it will copy and scan though.
OK, did you install the Easyshare software first before installing the printer? I've experienced technical problems with my Kodak camera when I do not have the Easyshare software installed.
Also, how did you install the Kodak ESP 5210 printer? Did you use the driver from the Kodak.com website, or the CD that came with it?
Good luck on getting the Kodak ESP 5210 printer to work on your computer system.
5helpful
2answers
Paper jam error light on kodak esp 5
  1. Remove the paper tray.
  2. Disconnect the power cord, wait 5 seconds, then reconnect the power cord.
    NOTE: The printer will reset and eject the paper. If the paper does not eject, try to remove it manually.
  3. Replace the paper tray.
  4. Press the Print button on the printer to resume printing.
Kodak ESP 5 Printer Logo
Top Kodak Office Equipment & Supplies Experts
Ekse
Joaquim Martins
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
